turbo wont build boost. HELP!!!!!!
Old Jan 25, 2003 | 02:18 PM
jdmtegxsi's Avatar
Default turbo wont build boost. HELP!!!!!!
I am having a major problem, I have been working on this turbo for many weeks now and it still wont build boost at 100% throttle. I can feel a difference at about 50-75% throttle but everything after that doesn't feel like it is building boost. I think it is my vacuum lines but I also think it might be a map sensor but I am not throwing any codes for it to be a map sensor. It would really help if anyone out there has had this problem before. I have a couple friends that have turbos and none of them can figure out what is wrong .But any suggestions would help right. I don't know what else to do.
Old Jan 25, 2003 | 02:20 PM
falcongsr's Avatar
What is this crap?
Default Re: turbo wont build boost. HELP!!!!!! (jdmtegxsi)
disconnect exhaust
Old Jan 25, 2003 | 02:21 PM
turbotypeR@SPEC's Avatar
25 Year Member
make sure you don't have any exhaust leaks before the turbo.a long time ago when i installed my first drag kit,i did not notch the block enough and i had the same problem.notched it a little more and it was fine.
Old Jan 28, 2003 | 08:42 AM
jdmtegxsi's Avatar
Default Re: turbo wont build boost. HELP!!!!!! (turbotypeR)
ttt
Old Jan 28, 2003 | 08:43 AM
trbob16a's Avatar
Do you have a boost gauge? Whats it doing.
Old Jan 28, 2003 | 08:57 AM
PM-Performance's Avatar
Default Re: turbo wont build boost. HELP!!!!!! (trbob16a)
yea check the gaskets, i had a leak from my manifodl gasket and wg gasket, i was still building boost, but wasnt what it shoulda been
91Honda_gsr
Oct 29, 2015 03:48 PM
kingzac876
May 16, 2012 09:00 PM
accord99power
Jul 23, 2010 09:06 PM
HondaTeKnology
Aug 17, 2009 11:25 AM
HondaH22a#1
Jun 16, 2008 08:07 PM
