vacuum connections........
Old Jan 25, 2003 | 01:33 PM
Scorch7's Avatar
Default vacuum connections........
I'm swapping a B18A1 ('93 teg) into a cx civic ('92). The fuel return outlet on the fuel pressure regulator is larger than the original one ane the fuel hose won't hook up. Has anyone else found this to be a problem and what did you do? Also, I can't seem to find the pressure reg. solenoid valve for it in my car either. Any thoughts? Thanks.
BTW I couldn't find any answers using search
[Modified by Scorch7, 10:34 PM 1/25/2003]
Old Jan 25, 2003 | 02:41 PM
Ministry's Avatar
Default Re: vacuum connections........ (Scorch7)
i put an h22a4 in my '92 civic VX. I cant imagine that the fuel return outlet on any B series motor is bigger than that of an h22, and im sure the VX hose is the same size as CX. The way I did it was to spray the outlet with a little silicone grease, and than use a hairdryer to heat up the hose. It was still a royal pain in the *** and a really tight fit, but I got it on there. try my method and dont give up
[Modified by dreamer, 11:41 PM 1/25/2003]
Old Jan 26, 2003 | 12:37 PM
Scorch7's Avatar
Default Re: vacuum connections........ (dreamer)
Hey thanks Dreamer. I will try some o-ring lube or something like that with a hairdryer.
cfiiman
Feb 20, 2014 08:59 AM
Dekorum
11
Dec 16, 2013 06:00 PM
deschlong
Sep 7, 2009 05:28 PM
Exempt
May 28, 2005 05:24 AM
