Fact or fiction: Race fuel on the ground = loss in octane
Old Jan 24, 2003 | 08:30 PM
A D NOH's Avatar
I really don't know
Community Builder
Default Fact or fiction: Race fuel on the ground = loss in octane
Is it true that when you store race fuel on the ground, it loses octane points?
Old Jan 25, 2003 | 08:29 AM
earl's Avatar
Default Re: Fact or fiction: Race fuel on the ground = loss in octane (TypeOne Enjoy It)
If you store it anywhere long enough, VP will turn to junk. I lost a motor and proved to myself that it was the fuel's fault. Never buy VP out of a 55 gal drum. Knowledgable shops will sell it to you in 5 gal cans.
Old Jan 25, 2003 | 10:42 AM
boosted3g's Avatar
Default Re: Fact or fiction: Race fuel on the ground = loss in octane (earl)
any idea on the length of time it will go bad. I have a 15 gallon drum now for about 6 months, would you run it or at least drive around to break the motor in with low boost, say around 15 psi
Old Jan 25, 2003 | 10:58 AM
earl's Avatar
Default Re: Fact or fiction: Race fuel on the ground = loss in octane (boosted3g)
I finally figured out my problem when I used the same fuel to start another motor. Would barely run and smoked like crazy. Drained the gas and put in pump and motor started and ran perfectly. Your VP could be ok but I know I would never use it.
Old Jan 25, 2003 | 11:45 AM
tractionbar2nr's Avatar
well, i don't think it is that the fuel loses its octane but more like builds up moisture. i do know that when storying a 55 drum you want to elevate it off the "cold ground" with some 2x4s. the gelling might be from the moisture that it builds with in the can. i do know that if you store the fuel correctly it will last over a year. just keep the lid tight, don't store in a cold place, and keep it off the ground. these are things i have seen work to keep fuel useable.
also check out http://www.vpracingfuels.com and maybe email someone there to get the correct info.
Old Jan 25, 2003 | 11:47 AM
dmotoguy's Avatar
Default Re: Fact or fiction: Race fuel on the ground = loss in octane (tractionbar2nr)
i HATE buying it in 5 gallon drums, but thats what we do... we have like 100 of them stacked up i our shop.
Old Jan 26, 2003 | 08:20 AM
earl's Avatar
Default Re: Fact or fiction: Race fuel on the ground = loss in octane (dmotoguy)
I will only buy them in 5 gal cans plus they are great for putting used oil in
Old Jan 26, 2003 | 10:47 PM
miller's Avatar
hell yeah on the oil disposal
Old Jan 27, 2003 | 03:43 AM
BudaKai's Avatar
Default Re: Fact or fiction: Race fuel on the ground = loss in octane (vtecdoc)
There's also a system to remove the condensation from the fuel that causes it to go bad.
adam00
Engine Management and Tuning
12
Dec 22, 2008 07:19 PM
99hondacura
Jul 30, 2006 03:09 AM
Running925
Jul 10, 2006 05:04 PM
Kwuaymaikrup
Feb 23, 2004 01:34 AM
variablevalve
15
Dec 25, 2002 07:47 PM
