Fuel smell coming from engine bay...
Old Jan 24, 2003 | 05:36 PM
92TypeR's Avatar
FSAE
Default Fuel smell coming from engine bay...
Well, I first smelled the fuel through my heater vent, and I pulled over right away, opened the engine bay and it was really strong...definately fuel vapors.
The fuel filter nut is tight, and I saw no leaks from the fuel rail and the stock fpr.
Any thoughts? I got the car home now, but any fuel leaks is not something I want to risk driving with...being on fire isn't exactly my favorite thing.
For the record:
Skunk2 chipped ecu, stock fuel system.
Old Jan 24, 2003 | 06:01 PM
RTW DC2R's Avatar
Default Re: Fuel smell coming from engine bay... (92TypeR)
did you just happen to get gas? one time i smelled gas, and thought it was leaking somewhere. turns out I had just gotten gas and I think i just had gas on my shoes. if thats not the case, and you dont see any leaks, check the underside of the injectors and make sure the seals arent screwed up. just work you way from the injectors, to the fuel rail, fpr and the fuel filter. good luck
Old Jan 25, 2003 | 08:46 AM
sgT's Avatar
sgT
Default Re: Fuel smell coming from engine bay... (RTW DC2)
thatsfunny,my car is doing that as well.
right now i suspect the evap but im gonna look over it again today now that i have light.
but this has been going on for a few days now at least
Old Jan 25, 2003 | 09:53 AM
01-1293's Avatar
Default Re: Fuel smell coming from engine bay... (sgT)
this definately didn't happen to you but....a month after I got my R.....I came out in the morning to drive back to my apartment and my fuel line ruptured and sprayed gas all under the houund........it was insane
Old Jan 25, 2003 | 10:36 AM
92TypeR's Avatar
FSAE
It has been happening for a couple weeks not that I think about it.
I do not have my evap hooked up. All my vacumn plugs are plugged on my IM.
I suspect it is my EVAP now that I think of it, because it is suppose to 'recycle' fuel vapors right? So if mine isn't hooked up, it will just leak the fuel vapors out into the open.
Old Jan 25, 2003 | 11:02 AM
vactor's Avatar
fuel return line?.
Old Jan 25, 2003 | 01:05 PM
skafia's Avatar
25 Year Member
Default Re: Fuel smell coming from engine bay... (vactor)
I think you are leaking fuel.
Old Jan 25, 2003 | 02:56 PM
92TypeR's Avatar
FSAE
Default Re: Fuel smell coming from engine bay... (skafia)
....from where...still havn't found anything
Old Jan 25, 2003 | 07:44 PM
92TypeR's Avatar
FSAE
Up.
Old Jan 25, 2003 | 08:02 PM
Nameless RB26's Avatar
When I did my swap, I didn't put the muffler washer on the fuel rail when connecting the fuel hose. It would leak a tiny bit and I could smell it... and when I kept checking for it, I couldn't see anything. I rubbed my finger on it and I could smell it on my skin, but couldn't see it because it was leaking out so thinly (is that a word?)..
I ended up tightening it more and it stopped. I lost the washer. This might not be the problem, but just letting you know it was kindof tricky looking for a little leak like that because I couldn't see it..
Old Jan 26, 2003 | 01:05 AM
92TypeR's Avatar
FSAE
Default Re: Fuel smell coming from engine bay... (Nameless)
Ya, its hard mainly because if there is a small fuel leak, it will most likely evaporate...
I'll give it a shot after work, and to you if thats it.
Old Jan 26, 2003 | 01:56 AM
sgT's Avatar
sgT
I'm definitely not.
still smells, didnt see anything, no smell from evap, no exhaust leak
<shrug> car doesnt catch fire, im just gonna push that recirculate button and go
back to sleep.
Old Jan 26, 2003 | 03:07 AM
uNF$@#!'s Avatar
I'm definitely not.
back to sleep.
stop bathing in gasoline
Old Jan 26, 2003 | 04:33 AM
Typel2's Avatar
Default Re: Fuel smell coming from engine bay... (Soup ****)
maybe is your feet.....
haha.. just kidding..
just did an oil change??
Old Jan 26, 2003 | 08:04 AM
92TypeR's Avatar
FSAE
Default Re: Fuel smell coming from engine bay... (Typel2)
No, probably should actually...just clicking over the 3k mark since the last one.
Old Jan 26, 2003 | 09:35 AM
TypeR 01 886's Avatar
I have been on fire before... with my GSR, its not fun! Please bring it to acura to prevent damage or injury! Tow it if you have to!
Plus insurance is a bitch... they always think you have done it for moeny.
They spend alot of time trying to blame you personally for insurance fraud, not fun!
[Modified by TypeR 01 886, 6:37 PM 1/26/2003]
Old Jan 26, 2003 | 01:40 PM
sgT's Avatar
sgT
Default Re: Fuel smell coming from engine bay... (TypeR 01 886)
HAHAHAHAHAHAHAHA
You gotta be kidding.
Old Jan 26, 2003 | 02:00 PM
Well he can at least blame it on them if they say "nothings wrong, we dont see anything" and he wont be responsable. I was not kidding.
Old Jan 26, 2003 | 02:02 PM
sgT's Avatar
sgT
you are better off taking it to your next door neighbor's 12 year old.
Old Jan 26, 2003 | 04:48 PM
92TypeR's Avatar
FSAE
LoL.
Well, I peaked under the hood for a while today, and ran the car...the fuel smell is definately coming from around behind the engine. I still couldn't see any leaks, which is good. I am going to drive it for about 1/2 hour then do another under the hood observation session and see if I can use my fabulous nose to sniff out the source. The fuel smell usually comes on strong after about 20 min of freeway driving.
Old Jan 26, 2003 | 04:51 PM
JPP's Avatar
JPP
You might want to check the rest of the gas lines coming from the gas tank to make sure there is no leaks anywhere (cracked line or something like that).
Novz
Jan 7, 2011 11:47 AM
Spectrum24x
May 1, 2008 08:09 PM
JBBNJ609
May 14, 2004 11:53 AM
azzenco
Jan 14, 2003 05:15 PM
AEGEAN
Dec 30, 2002 07:33 PM
