When sleeving to 84mm should i bother with matching the chambers?
Old Jan 24, 2003 | 02:34 PM
GEN2TEG's Avatar
Default When sleeving to 84mm should i bother with matching the chambers?
I was told by the people doing the sleeving on my block that i would have to match the chambers if i chose to go to 84mm sleeves, Is this true?
What are the pro's and con's of doing this?
Is my compression ratio effected? (pistons are currently 9.0:1 Wiseco's)
thanks,
GEN2TEG
Old Jan 24, 2003 | 02:50 PM
Kwuaymaikrup's Avatar
Default Re: When sleeving to 84mm should i bother with matching the chambers? (GEN2TEG)
Yes it will affect your comp. ratio. Any time you remove material you lower the ratio. As far as pros/cons I was wondering this myself.
Ryan
Old Jan 24, 2003 | 04:19 PM
boosted hybrid's Avatar
It will drop your compression by at least .4. I had my head ported, but left the stock 81mm bore. I am running a 84.5mm bore. I just have to be careful with my timing curves, to make sure that i dont cause hot spots on the edge sitting around the combustion chamber. In all honesty, you wont have a problem with doing it.
Old Jan 24, 2003 | 06:12 PM
GEN2TEG's Avatar
Default Re: When sleeving to 84mm should i bother with matching the chambers? (boosted hybrid)
anybody else?
Old Jan 24, 2003 | 06:22 PM
vtecvoodoo's Avatar
Future Texas Boy
I did it, but my head was at Portflow already. there was a good 5-6 page topic regarding this a few months ago. Search archived topics.
Ryan
Spawne32
Sep 26, 2010 10:45 AM
bigsnorlax
Sep 14, 2008 06:43 PM
vti2
Jul 5, 2004 08:13 PM
asubennett
Jun 10, 2004 04:10 PM
Mentat Ghola
14
May 11, 2004 02:35 PM
