Cam Gear design. Won't slip.
Co-workers friend makes these. Its the best design I've seen. You put a pin in the amount of degree adjustment.
[Modified by gtcali, 2:15 PM 1/24/2003]
I've seen these before....I looked at them before going with STR. I think the deal with these is you use the pin to make sure you're setting the gear where you want it and that it doesn't move when tightening the bolts. I think you take the pin back out when you're done adjusting, which would make them one bolt less likely to slip than an AEM
wako182774
Honda Civic (2001 - 2005)
Jun 16, 2007 05:29 AM
allicedout
Jun 17, 2004 04:57 PM
