forged piston daily drivers- looking for opinions on cylinder wear and oil loss.
Old Jan 24, 2003 | 09:40 AM
spettinger's Avatar
Default forged piston daily drivers- looking for opinions on cylinder wear and oil loss.
to those with forged pistons in their daily drivers, do you consume much oil, and have you seen your cylinder walls since putting the pistons in? are your cylinder walls worn in any way, from the looser tolerances that are present when the motor is first started? (piston to cylinder wall tolerance as compared to a stock cast piston with tighter tolerance.) thanks for your time.
[Modified by 2ndhandCRX, 7:55 PM 1/25/2003]
Old Jan 25, 2003 | 10:55 AM
spettinger's Avatar
Default Re: forged piston daily drivers- looking for opinions on cylinder wear and oil loss. (2ndhandCRX)
up
Old Jan 26, 2003 | 01:54 AM
sporkcrx's Avatar
bump
Old Jan 26, 2003 | 05:02 AM
keithv's Avatar
Default Re: forged piston daily drivers- looking for opinions on cylinder wear and oil loss. (sporkcrx)
not sure if you tried asking in the tech forum...
Old Jan 26, 2003 | 07:19 AM
Blown90hatcH's Avatar
When I had my EF with the B18c and Jackson @ 13psi. All I had done was rods and pistons and I drove that thing to school everyday. I put about 500 miles a week on that car. Boosted all the time. Drove it very hard. When I yanked the engine to get it sleeved, the walls were perfect. They had zero scaring. Didnt burn any oil.
HTH-Jason
Old Jan 26, 2003 | 08:29 AM
spettinger's Avatar
Default Re: forged piston daily drivers- looking for opinions on cylinder wear and oil loss. (Blown90hatcH)
wow. compression numbers were still good as well?
Old Jan 26, 2003 | 06:46 PM
Numbers were great. I was very precise with the tolerances in the bearings and filing the rings.
Old Jan 26, 2003 | 08:11 PM
sicivic's Avatar
Why would the tolerences be any worse with aftermarket pistons when compared to stock? They should be the same if not better then the stock tolerences.
Old Jan 26, 2003 | 08:20 PM
Default Re: forged piston daily drivers- looking for opinions on cylinder wear and oil loss. (sicivic)
Normally on most forged pistons, the piston to cylinder wall clearance is ran alittle larger. On mine, the clearances were larger because of the fact that I was under boost, normally around 3 or 3.5 thou.
J
Old Jan 27, 2003 | 10:14 AM
sporkcrx's Avatar
a charged gsr engine @ 13psi in a rex, ai chiwawa
what have you upgraded to know?
Old Jan 27, 2003 | 10:52 AM
Eggman's Avatar
You don't even want to know how much oil I'm burning. JE pistons on a sleeved block. I haven't seen the block since the build. 20K miles on the motor and it started to burn about 7K miles ago. The block's previous owner had JE pistons too. He said it didn't burn oil but he did have scarring on the sleeves. I'm going to do a leak down then if need be, [cross fingers] rebuild [/cross fingers].
Old Jan 27, 2003 | 11:01 AM
freud's Avatar
aftermarket pistons are forged, not cast like the stock ones. forged pistons are softer, more malleable. they expand more when heated. this is what gives them their strength.
Old Jan 27, 2003 | 12:20 PM
Yeah, that was in my 90 hb. I loved that car.
I am 00 hb turbo now.
Jeanious
Oct 28, 2007 03:44 PM
Import RP
Mar 24, 2006 03:38 AM
mz3bo
Jul 6, 2003 09:03 PM
crxhybrid1320
Feb 2, 2003 12:50 PM
spettinger
Jan 26, 2003 09:01 AM
