Newbie with Question on Headlight Replacement
Hi all from a newbie
My GF has a 2001 Honda Accor coupe with a burned out headlight.
Is it easy to replace? Any tips or tricks I should be aware of?
Thanks in advance. TruBlu
Oh yeah I forgot I can edit my own title! Yay!
Just make sure you don't touch the bulbs with your hands. If you have any kind of dirt or oil on your hands your bulb will fry.
rotate the black ring counter clock wise
remove bulb
replace bulb
rotate black ring clock wise
to remove light from connector
squeeze end of plug and pull the light out (it works on a 94 accord)
do not touch glass bulb with bare fingers as it will pop
I usually use a pair of rubber gloves
[Modified by YeuEmMaiMai, 11:50 AM 1/24/2003]
remove bulb
replace bulb
just dip your head in the hood you can kind see there's a gap when you can slide the bulb out..
low beam---hi beam.........
....hi beam...low beam
foglite........................................... ...............fog light
....hi beam...low beamfoglite........................................... ...............fog light
Thanks all.
Used the rubber glove idea and though it took a bit of effort to get the housing loose, I was able to replace the bulb with no problem.
it's much easier than changing lightblub on the i4 than v6(6th gen).
On my friend's v6 the intake resonator block most of the access to the blub.
it is the same with the I4 motor you have to remove the "Silencer" and then you have fairly easy access
Snowsrfr
Mar 4, 2010 10:17 AM
