ls/vtec questions..
ok i want eagle rods and ctr pistons
the eagle rods are setup for floating pin and the ctr pistons r solid right? .. so if i go to the machine shop i can juss let them know i want the rods pressed to the piston rings correct?
do u kno how much this usually runs? j/w
also will using the 98 ls bearings be ok to use instead of getting new ones? i know its better to get newer ones for dependability but those bearings should be ok to use correct?
any info asap would be appreciated
Dont thank it will work because you won't have any thang to hold the pin in place.Ctr pistons are floating pin.The factory rod is a press fit and thats what holds the pin in place.
As far as the bearings go save your money and buy new ones it is well worth it.
DO NOT RE-USE OLD BEARINGS
kdawgy2k1
Dec 9, 2007 06:09 PM
