B16a in 86 hf
Im just curious if any of you guys have done this same swap because i need to know if this list contains everything that you need. Because if everything on this list is a must, it'll be a lot more than i intended and i need to know what i can grab off of older cars and what needs to be bought. Thanks in advance
Sean
b16a and tranny
ECU
Motor Mount kit
Rear Mount
Axles
Intermediate Shaft
CV Joints
Knuckles And Hubs
Radiator Hoses
1992 GS-R Upper And Lower
Throttle Cable
Speed Sending Unit
Brake Booster Hose
Cluch Cable
Cluch
1990-1991 Integra/ Disk
Pressure Plate PN ,
fuel pump
Sean
b16a and tranny
ECU
Motor Mount kit
Rear Mount
Axles
Intermediate Shaft
CV Joints
Knuckles And Hubs
Radiator Hoses
Throttle Cable
Speed Sending Unit
Brake Booster Hose
Cluch Cable
Cluch
Pressure Plate PN ,
fuel pump
You will need to swap the fuel lines and tank as well. The tank is not the same as a fuel injected car and the lines need to be able to handle a high pressure pump.
I have a B16 in an 86 si crx and it made a huge difference in the required amount of work.
Makes for a quick car though.
freak86
Jul 30, 2006 09:19 AM
jbrown_6
11
May 11, 2004 03:49 PM
89_integraRS
Sep 15, 2002 09:24 PM
