the Differences between SOHC & DOHC
Old Jan 23, 2003 | 04:29 PM
neRd's Avatar
Default the Differences between SOHC & DOHC
Guys, im new to the tech world of honda's.. i just want to know the difference between SOHC and DOHC, what are some advantages and disadvantages.. I want to know the detail on both.. i hope im not the only one here who doesnt know the difference..
thanks.
Old Jan 23, 2003 | 04:37 PM
eg6ajk's Avatar
Default Re: the Differences between SOHC & DOHC (neRd)
dohc = double overhead cam
sohc = single overhead cam
in a DOHC it simply means that there are two camshafts which control the opening and closing of the valves. one for the intake side and one for the exhaust side.
in a SOHC one cam does all that. meaning that both profiles are on one cam.
in honda world DOHC motors are usually the performance oriented while the SOHC are bread and butter 'daily drivers'
DOHC allows for alot more adjustablity as well as more control over whats happening with the vlave train and so on. in the case of hondas 'extreme' control of valve lift with useage of VTEC. in DOHC VTEC you get intake and exhaust control while in the SOHC vtecs only the intake side.
all other honda motor are simply just like any motor out there with exceptions of rotation (hondas till '02 used to spin in counter-clockwise direction which was not seen anywhere else)
hope this helps, otherwise its time to hit:
http://www.google.com
http://www.howstuffworks.com
Old Jan 23, 2003 | 04:46 PM
altoid's Avatar
Default Re: the Differences between SOHC & DOHC (eg6ajk)
sohcs do rock though, they're all around inexpensive and you can still get hellish power out of them
Old Jan 23, 2003 | 04:48 PM
kyle h.'s Avatar
Default Re: the Differences between SOHC & DOHC (altoid)
sohc
one cam vs. two cams
timing is alot easier on the single cam motors....easier to work on and cheap parts
Old Jan 23, 2003 | 08:19 PM
neRd's Avatar
Default Re: the Differences between SOHC & DOHC (kyle h.)
thanks, i apperciate an honest answer.
Old Jan 23, 2003 | 08:54 PM
theclutchpoppa's Avatar
i applaud everyone for not flaming this man and giving him quality information!
Old Jan 23, 2003 | 09:30 PM
TEAMGENDAI's Avatar
Default Re: the Differences between SOHC & DOHC (theclutchpoppa)
One cam two cams i love them both. Its still a honda motor. built honda tuff.
Old Jan 24, 2003 | 04:44 AM
kyle h.'s Avatar
Default Re: the Differences between SOHC & DOHC (TEAMGENDAI)
built honda tuff.
a new salogan.
Old Jan 24, 2003 | 07:40 AM
madman13lm's Avatar
I couldnt agree more...
Built Honda Tuff??? It didnt work to well for ford
Old Jan 24, 2003 | 07:52 AM
JimBlake's Avatar
Well, my '95 GS-R is DOHC-VTEC, and the VTEC 'feature' is only on the exhaust cam. Just means it HAS 2 camshafts, doesn't mean both of em have VTEC...
DOHC puts a camshaft above each row of valves. Usually SOHC has to have longer or bigger tappets, to reach the valves. This means more reciprocating mass.
Old Jan 24, 2003 | 08:53 AM
LS-hatch's Avatar
also the dohc head/motor usually flows a lot better than the sohc.
Old Jan 24, 2003 | 08:57 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: the Differences between SOHC & DOHC (LS-hatch)
welcome to the wonderful world of hondas. Hope you.......well i know you will enjoy your stay.
daver
Sep 7, 2018 09:35 AM
Da D0n
Feb 24, 2008 02:31 PM
EdWord
Sep 17, 2006 09:26 PM
Mark80
May 14, 2006 08:01 PM
boy_honda
May 8, 2004 08:30 PM
