GS-R is going into boost this weekend, take out the ctr intake cam?
Old Jan 23, 2003 | 03:52 PM
Chrome Pipes's Avatar
Default GS-R is going into boost this weekend, take out the ctr intake cam?
I am installing a Drag turbo kit on a completely stock GS-R this weekend. The owner has a CTR intake cam, stock GS-r exhaust cam, Jg throttle body, Skunk 2 intake manifold, and AEM cam gears. VAFC, 440's and an Inline Pro headgasket are going on as well. Should I take this cam out considering the amount of duration it has, or leave it in? Has anyone tried this before with sucess? I would replace it with the stock GS-R intake cam. The car is going straight from the shop to the dyno when we are done. Thanks
Old Jan 23, 2003 | 03:55 PM
Sleepin''s Avatar
Default Re: GS-R is going into boost this weekend, take out the ctr intake cam? (Chrome Pipes)
I am running a B16B intake cam with a stock B16A exhaust cam. I never changed it back from my NA days. I am curious as well.
Old Jan 23, 2003 | 03:59 PM
Default Re: GS-R is going into boost this weekend, take out the ctr intake cam? (Sleepin')
yeah, the guy is a close friend so we are curious as to what will happen. I read somewhere that too much duration is no good for turbo but hell, why not try it?
Old Jan 23, 2003 | 04:27 PM
AtomiC SleepeR's Avatar
maybe you should try your ctr intake camshaft that should put more air into the combustion chamber and keep the exaust gsr camshaft for less overlapp.
try this whit a dyno session then swap out your ctr whit your gsr intake camshaft and compare
Old Jan 23, 2003 | 05:01 PM
crxhybrid1320's Avatar
Default Re: GS-R is going into boost this weekend, take out the ctr intake cam? (AtomiC SleepeR)
I read that the 8 second unibody Acura(forgot his name) was running the ITR cams and he ran 8's. CTR has more overlap however meaning the boost will exit right out the exhaust. Try each way and see, Maybe dyno with each cam installed.
Lots of other Turbocharged vehicles are running the factory OEM camshafts with their setups.
Old Jan 23, 2003 | 05:48 PM
Civic_intent's Avatar
Default Re: GS-R is going into boost this weekend, take out the ctr intake cam? (crxhybrid1320)
I believe the 8sec. uni-body would be Kenny Tran. Correct me if I'm wrong please.
Old Jan 23, 2003 | 06:18 PM
Default Re: GS-R is going into boost this weekend, take out the ctr intake cam? (Civic_intent)
I have discussed the cam with the guy who owns the car and we agreed to leave it in, see what hp#'s we come up with. It won't hurt to try, we might even switch it there if we have the time. I just have'nt seen enough info on this, even after searching so I want to see!!
Old Jan 23, 2003 | 08:20 PM
turbopanda's Avatar
i'm running JDM B18C-R spec98 cams (in & ex) on my teg.. haven't had it tuned yet, but wondering if I could make more power by dialing out the overlap with my cam gears, or if I should swap these cams with the 1st gen B16A cams from my civic.
Old Jan 23, 2003 | 09:00 PM
MotorMatrix.com's Avatar
I am a bad person
I beileve kenny runs gsr cams. tony1???? I have made over 500 hp on ITR cams. I have been happy with them. they sound very aggressive on a turbo car!!!
Old Jan 23, 2003 | 09:19 PM
BudaKai's Avatar
Default Re: GS-R is going into boost this weekend, take out the ctr intake cam? (MotorMatrix.com)
MOTORMATRIX.COM: I figured it was him because being the fastest uni-body, and in the eight's if I not mistaken here. What kind of compression are you running?
I'd think with the more aggressive intake cam you'd get better boost responsiveness. You know that dedicated turbo cams have larger lobes on the intake side than the exhaust. If you're able to dial out the overlap as much as possible you should make some nice numbers.
Old Jan 23, 2003 | 09:22 PM
I am a bad person
Default Re: GS-R is going into boost this weekend, take out the ctr intake cam? (tzsir)
I'm was running 9:1 when i made 565whp but now I'm going 10:1.
Old Jan 23, 2003 | 09:29 PM
RyanAutry's Avatar
Here are a few other uni-body's in the 8's
Lance HoLung
'92 Honda Civic
8.597 160.74
Kenny Tran
'92 Honda Civic
8.666 140.47
Bruce Mortensen
'00 Civic
8.782 164.62
Marty Ladwig
'03 Sunfire
8.916 154.53
JoJo Callos
'01 Acura
9.011 157.59
Gary Gardella
Honda Civic
9.099 166.94
I was here when Kenny Tran hit 8.666 140.47. . If he wouldn't of hit his parachute early, who knows what he would have run.
Old Jan 23, 2003 | 09:34 PM
I am a bad person
Default Re: GS-R is going into boost this weekend, take out the ctr intake cam? (RyanAutry)
I doubt marty or lance are running GSR or Type R cams.
[Modified by MotorMatrix.com, 1:35 AM 1/24/2003]
Old Jan 24, 2003 | 04:33 AM
Although, with the 3 degress of extra duration over an ITR intake cam, I think there may be TOO much overlap that can be dialed out with the cam gears. Correct me if I am wrong...
Old Jan 24, 2003 | 05:20 AM
ricodemus's Avatar
I have read many times on this board that ITR/CTR cams can make great power on a boosted setup, but they have to be tuned or they could be detrimental. Good luck...
Old Jan 24, 2003 | 05:46 AM
TurboR1391's Avatar
If I were you I would dyno with the GSR intake and pull some runs with the CTR intake, that way you have proof that one makes more power over the other.
Old Jan 24, 2003 | 06:00 AM
tony1's Avatar
Unfortunately it wasn't only the chute that slowed the run, the boost limit on the motec shut the motor down. It ran way more boost than we expected. Would've been and 8.47 or 8.48 according to the rest of the pass. Either way, that was with gsr cams, but we're having some custom cams made right now. When they're finished and tested, we will be producing and selling them. They will be for high hp turbo cars. The gsr cams work good, but there is alot of power to be had from a better set. I'll keep you guys informed when we get them finished.
[Modified by tony1, 9:02 AM 1/24/2003]
hondaeg8
Nov 22, 2004 08:56 PM
lo0nY
20
Feb 8, 2004 07:18 PM
racerboyb16
Oct 10, 2002 10:55 PM
Weslay
Mar 4, 2002 10:16 AM
