In Skafia's defense . . .
http://www.inte-r.com/
THat site actually lists a 00 Spec R. sgT laughed at him. Someone that reads JDM wanna translate that as see what the heck they are talkin about?
not exactly paste friendly, but via a web translator i got...
00 spec 3 door coupes 4 door hardtops
1. 8l DOHC VTEC+PGM-FI 1. 8l DOHC VTEC+PGM-FI
@œ Car name * type HONDA * GF-DC2 HONDA * GF-DB8
@œ Engine type B18C
@œ Transmission 5 fast manuals
@œ Size * weight
@Total length/full-width/total height (m) 4. 380~1. 695~1. 330 4. 525~1. 695~1. 365
@Wheel base (m) 2. 570 2. 620
@Tread (m) Before 1. 480
After 1. 485
@Roadspace (m) 0. 135
@Vehicle weight (kg) 1,080 1,120
@ABS equipped car 1,090 1,130
@ABS+SRS air bag equipped car 1,100 1,140
@Air conditioner +ABS+SRS air bag equipped car 1,120 1,160
@Riding in a car fixed capacity (name) 4 5
@Size length x width x height inside passenger compartment (m) 1. 650~1. 385~1. 090 1. 830~1. 380~1. 120
@œ Engine
@Engine type, number of cylinders and arrangement Water cooling serial 4 cylinder horizontal ranging (unleaded premium gasoline specification)
@Fuel room type Pen To roof shape
@Valve gear DOHC belt driving inhalation 2 exhaust 2
@Entire aerodynamic volume displacement (cm3 1,797
@Inside diameter x distance (mm) 81. 0~87. 2
@Compression ratio 11. 1
@Fuel feeder type Electronic fuel injection system (HONDA PGM-FI)
@Fuel pump type Electromotive system
@Fuel tank capacity (L) 50
@Lube capacity (L) 4. 8
@Lubricating system ˆ³‘—Ž®
@Ignition device type Full * transistor type battery ignition
@œ Efficiency
@The highest output (kW [ PS ]/rpm) 147 [ 200 ]/8,000
@Largest torque (N * m [ kg * m ]/rpm) 186 [ 19. 0 ] / 6,200
@Fuel consumption rate (km/L) 12. 8
@Minimum turning radius (m) 5. 7 5. 8
@œ Power transmission * running gear
@Clutch type Dry veneer diaphragm
@Transmission type Regular gearing system
@Speed change ratio 1st gear 3. 230
2nd gear 2. 105
3rd gear 1. 458
4th gear 1. 034
5 speeds 0. 787
Retreat 3. 000
@Deceleration ratio 4. 785
@Steering device type Rack & pinion system
@Tire 215/45ZR16
@Wheel size 16~ 7 JJ 5HOLE@PCD114. 3 +50
@Main brake
@Type * type Before 15 inch hydraulic type ventilated disks
After 14 inch hydraulic type disks@
@@œ Suspension
@Spring rate
@(Ksf/mm) Before 4. 5
After 2. 5? 4. 4
@Damper attenuation power
@(Kgf) (0. 3m/secŽž ) Before (Extension) 231/(shrinkage) 142
After (Extension) 100/(shrinkage) 59
@Stabilizer diameter
@(Mm) Before 25
After 23
@Suspension system ƒ_ƒuƒ‹ƒEƒCƒbƒVƒ…ƒ{[ƒ“ system (before/after)
@Stabilizer type Torsion * bar system (before/after)
@œ Engine type B18C
@œ Size * weight
After 1. 485
@œ Engine
@œ Efficiency
2nd gear 2. 105
3rd gear 1. 458
4th gear 1. 034
5 speeds 0. 787
Retreat 3. 000
@Tire 215/45ZR16
@Main brake
@@œ Suspension
@Spring rate
After 2. 5? 4. 4
@(Mm) Before 25
After 23
not sure why it's in skafia's defense but the only diff between 98 and 00 spec is the chassis code according to that site. the specs of the cars are no diff.
00 spec had yellow while the other years didn't. That's the only physically diff I can think of.
EVERYTHING is the same ( i read both pages using babelfish.altavista.com ) except: Color choice was different. that's it.
- Car name * type
HONDA * GF-DC2 '00 spec (3 door)
HONDA * GF-DB8 (4 door)
HONDA * E-DC2 '98 spec (3 door)
HONDA * E-DB8 (4 door)
[Modified by Chris N, 6:08 PM 1/23/2003]
[Modified by Chris N, 6:09 PM 1/23/2003]
- Car name * type
Only color is sort of dissappointing.
The ONLY difference I see on that entire page is the body code designation.
Goes from E-DC2 to GF-DC2
Everything else is the same.
Nowhere on honda's website nor in any literature I have read has ever
made any note of this. I chalk it up to some regular guy writing about integras
just like any other honda site you see out there. Nothing more
I suppose even a JDM Integra site could be wrong
I think I've even seen a 00Spec Type R badge somewhere.. anyway, the changes are there: Introduction of yellow exterior/interior, HIDs, and I think the 2001 integra type r website shows the introduction of the SRS Steering wheel also? Not sure...
Destiny Hooks
Jul 11, 2018 01:09 PM
VtecbOi
Apr 4, 2003 10:00 PM
krshultz
55
Oct 2, 2002 05:22 PM
