B20A5 crank questions
Old Jan 23, 2003 | 08:57 AM
Bnjmn's Avatar
Default B20A5 crank questions
Hello. I'm considering a deckplated block and the B20A5 is a perfect candidate for a crank because it is cheap, factory, and has a 95mm stroke.
Is there any reason for choosing an Eagle crank over this?
These fit into other B series blocks, correct? Do they accept B18A/B20B/Z rod ends?
Old Jan 23, 2003 | 09:30 AM
sgT's Avatar
sgT
Default Re: B20A5 crank questions (Bnjmn)
the b20a crank is not a direct fit. the eagle crank is.
to use the b20 crank you would have to grind down the rod journals
and move the thrust washers in the block which requires more machining
dart2.2
Dec 29, 2009 07:32 AM
HiGhOkTaNE
Jun 12, 2007 11:48 AM
hu
Jan 29, 2006 11:24 PM
egcivic123
Jan 15, 2005 12:38 PM
scooter
Mar 3, 2003 03:30 PM
