Is there anyway to move the front ac lines behind the center radiator support ?
sorry for the long title, but here it is, my IC id 3.5" deep and having a JDM bumper support which is only about 1/2" wide, there is not a whole lot of room to move my IC back far enough since the ac lines is in the way.
Can I undo the lines and move it back to behind the center bar on the rad support ? how would I go about doing this ? where do I need to disconnect them and move it back ?
PS: I don;t wanna hear, take out your AC
tia
stan
tia
stan
the bar that the line needs to go behind is bolted on the bottom. Unbolt it and bend it out a little and slide the ac line behind it. Bolt it back in and you're done. I've done it a time or two...
Unless the type r core support is different....
Stan I believe they both connect on the passenger side of the engine bay near the ABS. I am not quite sure if I remember right however. Basically You would want to release all of the freon and then undo the line, move as necessary, and then recharge your AC system.
If you can't do it however, I recommend you ditch the A/C.
It's added weight and all.
my a/c lines arent gonna be in the way...i bent mine when i had the drag 3 kit, they are pretty far back.....btw, im planning on cutting that tiny *** rebar, have you done this stan?
ps. answer your phone tomorrow if i call you early
im sure ill come up w/ some more gay questions
i am not sure if I cna cut it yet...if I can mount the ic on the support, yeah, I'll cut the rebar...
my ic is bolted up to the tiny rebar now...
i test fitted my big *** IC, and mine has to mounting brackets on the bottom, and one threaded fitting for the top.....gotta *** rig up a bracket somehow for the top, ill be doing that tomorrow prolly
release the freon from the top valve by the wastegate ?
Check your local autoparts store as they have the recharge kits. There is probably something in that kit you can use to release the pressure as well.
Correct. It's going to get damn cold and I honestly couldn't tell you a good way to release it w/out freezing your hand. My AEM intake back in the day had rubbed a hole in my AC lines, so I didn't have to vent it before the lines were pulled.
Yes you should be able to re-route A/C line with a "Soft" tube bender (3/4" & 1/2" size).
That's what I used to re-bend A/C lines from a TEG into my EG to make them fit/clear certain places ......... Patience is the key here though when working with a soft tube bender.
[Modified by Honda4CX-R, 6:18 PM 1/23/2003]
r-134 is the supposedly ozone safe stuff that can be legally released into the atmosphere. r-12 is the bad stuff that destroys the ozone layer and is illegal to release.
