Difficult cold starts
Old Jan 22, 2003 | 08:19 PM
vtec69's Avatar
Default Difficult cold starts
When i go to start my car when its cold i need to give it gas and let it idle at 2000 rpms for a min or so
if i let go of the gas the car stalls
i thought it was the battery so i got a new one but it still didnt start right up
anyone have any ideas???
TIA
-Brian
Old Jan 22, 2003 | 08:21 PM
Chris y0!'s Avatar
Default Re: Difficult cold starts (vtec69)
my car idles really high automatically (probably around 2K, i don't have a tach though) when i first start my car in the morning. maybe its an ECU problem?
pkek's Avatar
my b16 swap does this too....I have a mugen program and my motor is an old auto so whats up?
Old Jan 22, 2003 | 08:28 PM
euclid's Avatar
Default Re: Difficult cold starts (Spoon Hybrid)
i am idleing at nearly 4k in the morning, but it was like 4degrees today and yesterday up here in the north east. you might be higher than 2k, i dont know why that happens.
Old Jan 22, 2003 | 08:31 PM
vtec69's Avatar
Default Re: Difficult cold starts (euclid)
u must not understand
it wount turn over unless i give it gas and make it idle at 2k
-Brian
Old Jan 22, 2003 | 08:32 PM
tominos's Avatar
the reason why it idles higher when the engine is cold is so that the engine can warm up quicker. once it reaches normal operating temp, the idle should return back down to normal. by the way, is your car carbureted? what car/year? maybe you're not getting enough gas, when it's cold, the engine runs richer.
Old Jan 22, 2003 | 08:34 PM
vtec69's Avatar
Default Re: Difficult cold starts (tominos)
i have fuel injection and the motor is an ls/vtec and i have a walbro 190 fuel pump
Chris y0!'s Avatar
-Brian
yeah, but what im saying is that you shouldn't have to make it idle that high, the car should idle that high by itself.
Old Jan 22, 2003 | 08:35 PM
vtec69's Avatar
but if i dont give it gas it just stalls out
Old Jan 22, 2003 | 08:40 PM
Chris y0!'s Avatar
i don't know dude... i would just tune the cold idle speed. do i know how to do this? nope. good luck
Old Jan 22, 2003 | 08:45 PM
90accord1's Avatar
what tobody setup do you have? some of the older tbodys off the tegs did not have a air valve, not sure if thats what the exact name is but thats what its called on my ae86. anyways along side the aicv is the air valve, coolant runs through it and it has a spring in it with wax. whent he coolant get warms the spring releases or somehting and the idle goes down. either your missing this or it could be damaged. it should be located on the underside of the throttlebody. just a possibility.
[Modified by 90accord1, 11:46 PM 1/22/2003]
Old Jan 22, 2003 | 08:46 PM
EpDarks's Avatar
Perhaps you need to tighten your throttle cable?
Maybe worth a try to clean out your injectors/fuel system.
Good luck man.
Old Jan 22, 2003 | 08:57 PM
tominos's Avatar
whats your fuel pressure at? when your car is cold, it should idle at about 1500-2k.
Old Jan 22, 2003 | 08:59 PM
94hondaLS's Avatar
dude cars do this normally in the morning. it idles normally when the cars warm right? The computer knows the engine is cold because the signal from the ECT (engine coolant temp)sensor says so. In turn the computer tells the IAC (intake air control) to open the throttle plate open so the engine can warm faster. Just some knowledge for the one that didnt know why cars did this.
Old Jan 22, 2003 | 09:02 PM
94hondaLS's Avatar
TIA
-Brian
not sure on that one let me get back to you tomorrow. I will go ask the all knowing one. if i were to guess though id say i has something to do with IAC
[Modified by 94hondaLS, 10:03 PM 1/22/2003]
Old Jan 22, 2003 | 09:03 PM
Chris y0!'s Avatar
Default Re: Difficult cold starts (94hondaLS)
yeah i know, maybe i should have reworded my first post. i meant to say that my car idles at 2K+ when i cold start it, maybe YOU have an ECU problem.
Old Jan 22, 2003 | 09:08 PM
poo flinger
Guest
Posts: n/a
Check your TPS sensor. Should be .4 volts at idle. .5 at half throttle. Also check the map sensor for any pinched vacuum lines. Check your IAC valve. Make sure the valve inside is all the way tighted.
Old Jan 24, 2003 | 04:05 PM
vtec69's Avatar
Default Re: Difficult cold starts (I can't believe this ****)
bump
99siRACER
Jan 17, 2012 03:47 PM
civicef990
Nov 21, 2011 04:14 PM
airikkCRX
Feb 20, 2009 05:37 PM
B_1_8_hatch
Mar 22, 2004 07:18 PM
