ignition, stock or aftermarket?
Old Jan 22, 2003 | 12:24 PM
bacardiman's Avatar
Default ignition, stock or aftermarket?
I just installed a 95 f22b1 w/ about 30k on it in my clean 94 ex. I am going to need to replc my plugs, wires, and rotor. should I go w/ MSD packages w/the external coils, and 8.5mm wires. withe the modified dist? or just stay Honda stock.
does the MSD set up really improve perfor. that much?
Old Jan 22, 2003 | 01:04 PM
Perfectionist's Avatar
Default Re: ignition, stock or aftermarket? (bacardiman)
OK, I'm going to stick my inexperienced nose in here. I prefer the stock OEM equipment and NGK plugs. I realize in some specialized applications aftermarket ignitions may improve performance. But I have to ask... If you lit a firecracker with a bigger match, would the bang be louder?
Old Jan 22, 2003 | 02:09 PM
Lord Helmet's Avatar
only if you're running high compression, nos, or turbo I can see using the msd if it's relatively stock internal and bolt ons I say stick to stock. my .02
OMG WTF
Nov 15, 2006 10:29 AM
DarkDragon
Jan 30, 2005 08:33 AM
DCtwoR
Aug 16, 2004 11:49 AM
92HB_HB
Apr 7, 2004 03:50 PM
Cashflo
Aug 11, 2002 12:35 AM
