Will this clutch and flywheel work?
Old Jan 22, 2003 | 12:01 PM
2muchPSI's Avatar
Default Will this clutch and flywheel work?
Hey guys, i have the clutch and flywheel off of my ys1 b17 transmission. Will it swap over to an s80 gsr transmission? Thanks
Old Jan 22, 2003 | 09:52 PM
Passaudi1.8t's Avatar
New User
Default Re: Will this clutch and flywheel work? (92tealvx)
The clutch disk and flywheel should work, but the pressure plate won't. Cable clutches are different than ones for hydraulic transmissions.
[Modified by vtecivicex, 6:53 AM 1/23/2003]
Old Jan 22, 2003 | 10:03 PM
sgT's Avatar
sgT
Default Re: Will this clutch and flywheel work? (vtecivicex)
No no no
flywheel and pressure plate WILL work.
the disc may or may not. 92-93 Non vtec integra are the same as later models, but im not sure
about the 92-93 gsr. Easy way to check is to try to put the disc on the newer trans.
It should be the same as well though.
Old Jan 23, 2003 | 08:52 AM
2muchPSI's Avatar
Default Re: Will this clutch and flywheel work? (sgT)
ok, does anyone know for sure ? I cant try to put the clutch disk on because the engine is over an hour away . Thanks
Old Jan 23, 2003 | 09:06 AM
eg6ajk's Avatar
yes it will work. we have a YS1 running an ITR clutch combo without problems. I ran a YS1 disc in my B16A (EG) for very short while as well.
the only b-series disc thats different is the 90-1 which was found in S1/J1/Y1 tranny. (flywheel and pressure plate will)
methanemotorworks
Feb 13, 2006 07:32 PM
DPSJosh
Aug 26, 2005 06:09 AM
Overblown-Teg
Apr 22, 2005 11:18 AM
matthevelli
Apr 7, 2005 12:01 PM
thecorey
Sep 27, 2002 03:03 PM
