jdm d15b
WHat is need to put on of these into an EG....which ecu and wiring harness should I use....
does anyone make internals for this motor....I was thinking of buying one only like 500 what do you think?
i used to have it. its nothing more then d16z6 head with vx bottom end (block), power output is around the same mark as d16z6 but with 2-4lb.ft less torque.
original ECU is a JDM P08, harness use your harness and add vtec wiring if necessary.
check out my projects:
http://hyper.phluid.net/projects.html
PotatoePAPA
Mar 22, 2003 04:25 PM
