camber kits?
Old Jan 21, 2003 | 10:09 PM
686's Avatar
686
Default camber kits?
i got eibach sportlines springs, its a 1.8"f and 1.7"r drop, it will probably settle a little closer to 2". so i was wondering if i need to get a camber kit or should i just get a GOOD ALIGNMENT. i've been told that anything more than a 2" you will need a camber kit and it will be close to 2", so what do you guys think?
i did the search and didn't find anything that really answer my questions, so if you guys could help that would be kool.
Old Jan 21, 2003 | 11:08 PM
iam7head's Avatar
Default Re: camber kits? (686)
you dont need one imo
but is more of a personal thing..
some ppl slammed their ride and have nothing work on suspension.
when some rich **** put a camber correction kit on a sissy 1.0inch drop.
imo anything under 2 are okay..
i wont do it in any of eibach's spring..
Old Jan 21, 2003 | 11:10 PM
iam7head's Avatar
Default Re: camber kits? (iam7head)
rotate tires every 4-5k, check for sight or abnormal wears, alignment is a must, but allow 2 week for spring to settle.
all four wheels alignment is req. let them know you had your car lowered,
request a spec sheet, request to correct camber and toe as close as zero as possilble.
toe eat up tires ten time faster...well maybe 9.98 times.
Old Jan 22, 2003 | 01:24 PM
ULTRA911's Avatar
you might as well do the rear camber, only cost about $.50 to do. just a bunch of washers you get from the hardware stores, may be cheesy, but works! if i could only get a scanner to scan the progress instruction sheet.
dwarrick
May 11, 2006 10:20 AM
civic2000
Jan 7, 2005 11:00 AM
jdm_loser
Oct 20, 2004 12:46 AM
pacman86
Jun 29, 2003 03:03 AM
toooslow
May 7, 2003 12:38 PM
