2 Layer head gasket?
Old Jan 21, 2003 | 09:59 PM
zCivic's Avatar
Default 2 Layer head gasket?
Plan on using a OEM honda/acura head gasket for a LS/VTEC build up. Wanting to only use two of the three layers. Which of the 3 layers are used for this?. Any special tips for installing this other then cleaning them with part cleaner spray then copper spray??
TIA
Old Jan 22, 2003 | 08:54 AM
zCivic's Avatar
Default Re: 2 Layer head gasket? (zCivic)
ttt
Old Jan 22, 2003 | 03:29 PM
zCivic's Avatar
just need a little info. Been told on how to run a single layer but unsure how safe this is. If its safe will do this just need some info.
Old Jan 22, 2003 | 05:18 PM
Kataku2K3's Avatar
I personally will never take apart an OE headgasket.... There is no problem with doing so but getting a good seal is the tricky part... You probably have about a 50/50 chance of getting a full seal.. If you chose to use two layers then it really doesn't matter, you'll use the middle layer and either the top of the bottom. You'll get a jump in compression but it's up to you to decide if it's really worth it... I go by this.. an OE headgasket is 0.029" for each layer you take out you're pulling about 0.010" which ='s ~0.25:1 just in compression with a standard bore... So you figure the most you're probably ever going to get is about 0.50:1 over stock... I just like OE headgaskets the best (best sealing and they always fit right)... If you do go aftermarket then I would check into the Cometic lineup... Peace
dc4teg95
Dec 31, 2010 05:44 PM
Westrock2000
Feb 15, 2003 01:00 AM
zCivic
Jan 11, 2003 12:35 PM
94gsr
Sep 12, 2002 11:37 AM
