B series tranny question
Old Jan 21, 2003 | 09:47 PM
sparkz's Avatar
Default B series tranny question
I've got a GSR trans with R LSD. Broke the final drive and counter shaft and had those replaced. Now when I drive, and make turns, it makes violent knocking and shaking. Only happens when turning though, going straight is ok. Ive tried replacing the axles, had new diff bearings installed and it still does the same thing. Last thing I havent tried replacing is the diff. Anyone have any ideas on what could be wrong?
Old Jan 21, 2003 | 11:36 PM
TmeX05's Avatar
Default Re: B series tranny question (sparkz)
i have the same problem ..... anybody wit an answer?
Old Jan 21, 2003 | 11:41 PM
Kamin's Avatar
diff could be fucked.
Old Jan 22, 2003 | 12:05 AM
texan's Avatar
Default Re: B series tranny question (Kamin)
It's pretty tough to break a helical diff. One question though: why didn't you taken this to a qualified technician THE DAY IT STARTED HAPPENING?
Online discussion boards are a very bad place to get real mechanical help, as it most often takes a careful, in person inspection of the problem to figure out the solution.
[Modified by texan, 1:06 AM 1/22/2003]
Old Jan 22, 2003 | 05:44 AM
Hbgsr's Avatar
When that has happened to me and a few others it was the diff. You may have some of the pieces that broke off stuck down inside of the diff.
ExVtec
May 16, 2008 05:30 PM
hitekper4mance
Jun 7, 2007 10:37 AM
Takumi Fujiwara
Apr 22, 2006 12:52 AM
bryanb2
Apr 2, 2005 06:29 AM
ABK
Apr 6, 2004 08:30 AM
