Stuck in park, need help...
Old Jan 21, 2003 | 08:51 PM
hybrid_KJ's Avatar
Default Stuck in park, need help...
Just finished an automatic jdm b16a swap into a 93 dx sedan. Car runs and shifts fine but I can't get the shifter out of park without sticking the key in the release slot. I don't know auto trannys too well so I need some help. I'm going to check the brake lights and fuses along with the brake switch. Any other ideas/solutions?
PS. this is not my car so don't ask me why I didn't switch to manual.
KJ
Old Jan 22, 2003 | 04:01 AM
hybrid_KJ's Avatar
Default Re: Stuck in park, need help... (hybrid_KJ)
ttt, need some help.
Old Jan 22, 2003 | 04:08 AM
nsxmatt's Avatar
Sounds like something to do with the switch on the brake. Does it do that click when you apply the brake like it's unlocking the shifter?
Old Jan 22, 2003 | 05:57 AM
RaceTilIDie's Avatar
Default Re: Stuck in park, need help... (nsxmatt)
Sounds like the brake switch or the shift lock solenoid.
Old Jan 22, 2003 | 06:39 AM
hybrid_KJ's Avatar
Default Re: Stuck in park, need help... (RaceTilIDie)
where is the shift lock solenoid?
Old Jan 29, 2006 | 11:50 AM
Anthony's Avatar
Mr. Fuch-yu
Temporary fix until you are able to get the proper solution... Put a popsicle stick in the release slot. It works. Or he could get an aftermarket shift **** and install it to where he doesn't have to use the button. That is how my **** is done. Its been that way for 3 years and has absolutely no negative effects on anything. I know this is not the answer that you were looking for, but it will work. Hope this helps.
-Red
Old Jan 29, 2006 | 07:29 PM
pimpinpetree's Avatar
i had the same problom with my crx auto all i did was change the computer somone put the wrong computer in it which wouldnt let the car go out of park.... did it have an auto in it before or did u do a swap... also try the switch if u dont hear a click when aplaying the break then try to unplug the wires and reconnect worked for me good luck
DeeFry
Dec 2, 2018 09:41 AM
Entaka
Jun 14, 2008 10:00 PM
boblikesrock
Nov 29, 2006 06:55 PM
webthread
Sep 21, 2005 06:41 AM
yellowdcn
Feb 28, 2005 01:06 PM
