help... my car wont start!!!!!!!
I have replaced the starter with a new one and sometimes whan i try to start the car i step on the clutch and turn the key and nothing.. i play with the key and after 2-3 clicks it finally starts. but today it did not want to start, the battery is fine... i finally had to push start the car.
WTF??????
Its a stock OEM Honda Starter.
There is a good power and ground connection.
I researched the issue a little further and I see that there is a recall on the ignition switches on the 1997 Accords.
More info can be found here.
http://www.hondastyle.com/news/wmview.php?ArtID=52
The only true way to find out if an engine is bad is to a compression test. Now you want to test the compression while starting, and while running to. Now as i recall an engine runs with about 40 to 70 p.s.i. and when starting about double to triple the p.s.i. :
its the ignition switch, lucky for me i work at a dealer.
my motor is running good, i raced a s2k and smoked it pretty bad.
if the connections are good and the problem persists, try hitting the starter with your tire iron or something. when mine started to go bad it would lock up and when i turned the key i heard nothing. hit it to free it and give it a try.
This is what happens if a ignition switch is bad.
you turn the key, and the car starts. But it dies
when you let the key back. The car will run as long
as you hold the dey in between the star and run position.
runitup
21
Dec 26, 2020 05:17 PM
