where does the coolant go?
Old Jan 21, 2003 | 06:49 PM
redsled00's Avatar
Default where does the coolant go?
Alright, my girl has a 95 civic lx with a lot of miles on it. Every couple of weeks, the car starts to run hot. When I check the coolant level I have to add about a pint of water. I changed the therastat and there are no leaks. I thought the head was cracked but I checked the oil and there is no coolant in there either. The water pump is working since the water is circulatating in the radiator. So where does the coolant go????
Old Jan 21, 2003 | 07:27 PM
Blaze45's Avatar
Brrraaaap!
Default Re: where does the coolant go? (redsled00)
Thats a good question, my CRX does the same thing, so once it was to a certian level I didnt put anymore in and now it just sits there, loses a lil over time but not a pint...
Blaze
Old Jan 21, 2003 | 08:05 PM
NVMYSi's Avatar
Sounds like maybe a headgasket issue.
Old Jan 21, 2003 | 10:41 PM
BuddhaSiR's Avatar
Default Re: where does the coolant go? (NVMYSi)
You don't have any external leaks and you don't have any in your oil. Its gotta go somewhere. I would definately suspect your headgasket.
Old Jan 22, 2003 | 06:15 AM
kyle h.'s Avatar
Default Re: where does the coolant go? (BuddhaSiR)
does the car fog up at all? any coolant leaking down the block? what about the resivoir tank...full, empty?
Old Jan 22, 2003 | 07:40 AM
X2BOARD's Avatar
Default Re: where does the coolant go? (kyle h.)
Also check the radiator at the bottom... there is a small channel down there on the rad. that some water can collect (hide) and dissipate. Another thing to check is the top and bottom of the radiator, as it is plastic and if it's cracked... will leak some steam which will leave no evidence on the ground of a leak.
X2
tianporn
Feb 26, 2011 10:58 PM
SeanK325
Jun 22, 2010 02:52 PM
flipldls
May 9, 2010 02:14 PM
oneludesol
Jan 4, 2010 07:47 AM
som3on3_10
May 18, 2006 06:56 AM
