koni yellow perch setting
Old Jan 21, 2003 | 04:15 PM
rasta420's Avatar
Default koni yellow perch setting
i have some koni yellow shocks, and i heard that you can adjust the perch setting to make the car sit higher or lower? ive had these shocks for about 5 months now and i just figured that out. now how do i change the perch setting? just take off the shock, move the perch, and will it lock there in place? right now its on the middle perch i believe, out of 5 perch settings. which way makes the car sit higher, which way makes the car sit lower? set the perch down lower for the car to sit higher? its way too low right now for winter driving, and i wanted to raise it up at least an inch or so. does it really make the car sit higher/lower noticeably?
thanks
slammin86
Suspension & Brakes
Jan 20, 2009 05:00 AM
shadohconspiracy
Suspension & Brakes
May 15, 2008 05:54 PM
bbhockey19
Feb 8, 2007 09:48 PM
rasta420
10
Jan 24, 2003 11:28 AM
taytay333
Mar 25, 2002 09:07 PM
