How does an LSD work?
Old Jan 21, 2003 | 02:21 PM
Adampops's Avatar
Default How does an LSD work?
I was just wondering how an LSD works? How does it know which wheel is slipping and which wheel is gripping? Thanks for your help!
Old Jan 21, 2003 | 03:16 PM
Lsos's Avatar
Default Re: How does an LSD work? (Adampops)
I don't think anyone knows how a helical one works. I've heard explanations and all sorts of descriptions, but it just seems like regurgitated info that nobody understands. I looked at diagrams and even took one apart. Maybe I was missing something, but it just went right over my head. Good luck with that one.
The clutch ones are easy to explain, but I don't know how to and so I'll leave that to someone else.
Old Jan 21, 2003 | 05:08 PM
Adampops's Avatar
Default Re: How does an LSD work? (Lsos)
ttt
Old Jan 21, 2003 | 06:15 PM
dynamite C1's Avatar
getting back to the situation in which one drive wheel is on the ice and the other one has good traction: With this limited slip differential, even though the wheel on the ice is not able to transmit much torque to the ground, the other wheel will still get the torque it needs to move. The torque supplied to the wheel not on the ice is equal to the amount of torque it takes to overpower the clutches. The result is that you can move forward, although still not with the full power of your car.
sound like, it transfers power from the wheel that slips, to the wheel that grips.
[Modified by dynamite C1, 3:15 AM 1/22/2003]
Old Jan 21, 2003 | 06:48 PM
PSU-TEG's Avatar
Go to this site! It is better that one of us trying to explain it, and it has good illistrations of how the differentals work.
http://www.howstuffworks.com/differential.htm
Old Jan 21, 2003 | 08:07 PM
Adampops's Avatar
Default Re: How does an LSD work? (PSU-TEG)
Wow, thats a great website. Thanks for sharing that w/ me. Thanks for all your replies!
Old Feb 27, 2003 | 09:06 AM
Muckman's Avatar
Moderator in Chief
Whats the difference between a 1.5 way LSD and a 2 way LSD?
Old Feb 27, 2003 | 09:19 AM
92sleepR's Avatar
New User
I don't think anyone knows how a helical one works. I've heard explanations and all sorts of descriptions, but it just seems like regurgitated info that nobody understands. .
LOL. very true. All I know about the Quaife is that it works and uses some sort of gear face slip angle / coeficent of friction voodo. Someone tried to explain it to me once and it just made my head hurt.
The clutch types are pretty straight forward though.
Old Feb 27, 2003 | 09:55 AM
John's Avatar
New User
Default Re: How does an LSD work? (Muckman)
A 1.5 way locks completely under acceleration and partially under deceleration while a 2 way locks completely under acceleration and full under deceleration.
Old Feb 27, 2003 | 04:56 PM
Muckman's Avatar
Moderator in Chief
Default Re: How does an LSD work? (DunReit)
ok so it sounds like a 2 way is clearly better. whats the catch? Howcome most aftermarket LSDs are 1.5 way - Quaife, Spoon, well even OEM too.
Old Feb 28, 2003 | 06:18 AM
John's Avatar
New User
For a FWD car, a 1.5 is better. For a RWD car, that's a different story... I started a thread yesterday regarding this issue: https://honda-tech.com/zerothread?id=427817
em1gangsta
Jan 24, 2008 11:20 PM
jdm type s
Dec 27, 2004 01:36 AM
speedminded
Sep 5, 2004 06:49 PM
JDM_JON
Jan 9, 2003 07:22 PM
celica73
33
Aug 21, 2002 10:33 AM
