Help!! dimming gauge and headlights in 97 ex
OK...first off i would like to thank anyone that can help me w/my
probem
I just bought the car and it was owned by an older woman so i know
it wasn't beat on...Sometimes when i am driving my gauge lights
and headlights will dim then come back to normal...it has nothing to
do withe the speed of the car or the rpm's.and the problem is not
consistant..it seems like it happens more down bumpy roads but i
am not sure...Once again any help is appriciated thanks,
Nate
probem
Nate
first off your in the wrong forum but i'll try to help you anyway... check all of your fuses and make sure they are all correct and not blown... take out the gauge cluster and check all of the connections and the little lights that light up the gauge faces... maybe they are loose... check all the wires and look for exposed wires... check your grounds... if all else fails, maybe yoiu just need a new battery... good luck with your car and finding the right forum
97_delsol_Vtec
Feb 4, 2006 01:10 AM
Natedogg81
Jan 26, 2003 08:01 PM
Natedogg81
Jan 21, 2003 01:06 PM
