OBD-1 conversion question...B18B LS
Old Jan 21, 2003 | 06:34 AM
Doodoo's Avatar
Default OBD-1 conversion question...B18B LS
I did my conversion last weekend on my B18B. It went well, got the harness from Blown90hatch, niiiiice!!
My question is what year distributor did you all use?
I have a 92-93 and it doesn't fit on my head!! Only 1 bolt lines up!!
When I put the key in start position the distributor whines, before I start it, weird.
I know for sure its pinned right.
Is the 94-95 distributor different?
Thanks.
Old Jan 21, 2003 | 07:11 AM
Jaker's Avatar
Default Re: OBD-1 conversion question...B18B LS (Doodoo)
Do you know for sure that you got the distributor that originally came with the B18B? Or are you trying to use the distributor from your D series motor? If you want it to bolt up, you'll need a B series non-Vtec distributor, and for OBD1 it'll have to be either a 92-95, or you could use a 96-up if you want to change dizzy plugs.
Old Jan 21, 2003 | 08:16 AM
Doodoo's Avatar
Default Re: OBD-1 conversion question...B18B LS (Jaker)
I pulled off a 92 LS myself at the junkyard. My 90-91 distributor fits fine, all three holes. This other on just one hole. The head it is going on is from 94.
Old Jan 21, 2003 | 09:19 AM
spettinger's Avatar
if you use a 94 head, then you will need an OBD1 B series non vtec distributor. 94-95 ls. or 96 up with the plugs changed.
Old Jan 21, 2003 | 09:23 AM
Doodoo's Avatar
Default Re: OBD-1 conversion question...B18B LS (2ndhandCRX)
yeah thats what I needed to know...thanks.
6doorsentra
May 30, 2006 07:12 PM
egvtec
Aug 10, 2004 10:25 AM
Cjsls
Feb 10, 2004 06:33 PM
nevin
Aug 14, 2003 07:02 PM
20lb.teg
Feb 6, 2003 05:30 AM
