AFter your block got resleeve...Linebore....
i hear some people's line bore was messed up after they got their blocks back.. this true... how did u fix it.. i spun to mains in my old h23 block.. i could linebore it if u guys linebore yours after sleeves are put in.. i just dont really trust linebored block and timeing..
The easiest way to check your align bore is to install the crank. If it turns easily, you have no problem with your align (line) bore. If it freezes up and your bearing clearances are ok, look to the align bore for your problem.
BoostedH23a1
Feb 8, 2004 05:46 PM
