Weird electrical problem
Old Jan 20, 2003 | 07:16 PM
RCautoworks's Avatar
Default Weird electrical problem
Well if you have been following up on my previous problem, then you know I have been having some problems with my car. Click here https://honda-tech.com/zerothread?id=390368 to read my other problem
. Well, today I noticed that when my car was warming up, my dash lights would flicker on and off, and my thermostat needle would go up and down untill it goes to its final resting place. What could be causing both of these problems ? I bought a new alternator so its not that. I was thinking brand grounds. What do you think ?
Old Jan 20, 2003 | 08:29 PM
skud_dusty's Avatar
Default Re: Weird electrical problem (90blackcrx)
hit up the grounds dude. all i did to fix my problems (yours sound somewhat similar) was replace the grounds for the starter, tranny, engine, and battery
i isolated the tranny ground from the battery ground, a replaced my fuse box power wire, my starter power wire, and replaced my battery terminals. you can do this for like $10, and even if it doesnt fix it, is a worthwhile investment.
get 2 feet of 4 gauge, and 4 feet of 8 gauge. i think this is what i bought
good luck man
Old Jan 20, 2003 | 09:05 PM
MONSTERZC's Avatar
Just replace all of the grounds and you can make some new ones with 4 gauge wire and ring term. hope this helps
Old Jan 20, 2003 | 09:34 PM
Default Re: Weird electrical problem (MONSTERZC)
Cool thanks, one last question. About my temperture gauge needle like going up and down alittle, well it does this but then gets to the final resting point and stops, which has been the same spot for years. Do you guys think I am fine ? Also I just noticed, if the car sits at idle for along time, it will jump from 1,000 to alittle over like, 1,200. Could this be bad ground to ?
[Modified by 90blackcrx, 12:38 AM 1/21/2003]
Old Jan 21, 2003 | 04:27 PM
Now my emergency brake light will not go off, any ideas ?
AmauryR
Apr 7, 2008 05:16 PM
Veezy
Audio / Security / Video
Mar 24, 2008 07:49 AM
Pooby88
Jul 2, 2006 05:09 PM
iheartmyej8
Mar 4, 2006 03:20 PM
THMotorsports
16
Aug 17, 2005 05:57 PM
