Battery drain problem
Old Jul 2, 2006 | 09:13 AM
Pooby88's Avatar
Default Battery drain problem
I have a '91 Integra LS, stock, with a brand new battery. Here's the problem: after sittting for several hours, the battery will be dead. It doesn't seem to be the alternator, because after driving for awhile, the car will start right up. It only seems to happen when it has sat for several hours. Something seems to be draining the battery when the car is off.
Here's a hint: I just bought this car, and it didn't seem to have any electrical issues when I bought it. A couple days after I bought it I replaced the thermostat. I disconnected the starter ground wire on the thermostat housing. I hooked it back up the same way it was, but I can't think of anything else that could be causing it.
Any ideas on where to start?
Old Jul 2, 2006 | 10:57 AM
Pooby88's Avatar
Default Re: Battery drain problem (Pooby88)
bump
Old Jul 2, 2006 | 10:58 AM
qfast817's Avatar
check the fuse box under the hood, look for the battery fuse.
Old Jul 2, 2006 | 02:29 PM
Pooby88's Avatar
Default Re: Battery drain problem (qfast817)
Fuses are all good.
Old Jul 2, 2006 | 05:09 PM
6doorsentra's Avatar
take off your positive wire from battery. touch it back again, see if you can hear or see anything kicking on when you do so...maybe a short somewhere..
touch the terminal, then remove it, repeat..
navi510
Jul 6, 2017 08:53 PM
toner297
Honda Civic (2001 - 2005)
12
May 24, 2011 12:39 AM
Senbonzakura
Jan 19, 2008 01:54 PM
Ruben19
Oct 10, 2007 08:49 AM
braypunt
22
Sep 11, 2005 09:10 AM
