bonnet cooling
Old Jan 20, 2003 | 06:36 PM
NZ Vtec Weapon's Avatar
Default bonnet a.k.a HOOD ,cooling
this is a drag technique i guess,its when you put nuts in between the 4nuts and the bonnet,thus making the bonnet stick up at the back,and then you remove the rubber seal at back of engine bay,the idea is to let hot air be sucked out(when racing) and when waiting between dragsmlet hot air get out,its also ment to keep ya times more constant. Whats peoples comments on this?????? this is going to be foe a gen4 prelude,im also thinking of moving the license plate to make it more aerodynamic??
[Modified by NZ Vtec Weapon, 4:10 AM 1/23/2003]
Old Jan 20, 2003 | 08:30 PM
b19coupe's Avatar
Default Re: bonnet cooling (NZ Vtec Weapon)
FYI-in the states the "bonnet" is called the hood. Many people here have no idea what you are talking about. As far as the technique that you are asking about, I could not tell you if it works or not. Perhaps you could monitor underhood temps with and without the mod to see what works best.
prayludin
May 5, 2006 12:54 PM
staticrex
Jul 5, 2004 02:05 AM
vtec.dc2
May 8, 2004 05:22 AM
LillDragun
Sep 6, 2002 09:40 AM
Redsun
Dec 1, 2001 03:25 PM
