eletrical oriented people..help making o2 simulator
Old Jan 6, 2003 | 04:31 PM
BlueSi2k's Avatar
Default eletrical oriented people..help making o2 simulator
I attempted to create the o2 sensor simulator from this page:
http://www.jdmfan.com/technical/perf...nsor_simulator/
Everything looks good but for some reason the voltage switches from 0v to .001v instead of 0v to 7v. Can someone possibly guide me in the direction of my mistake or mistakes? the timer is definetely working..the red power led changes brightness every 3.3 seconds when the timer is supposed to switch. Any help is appreciated...thanks
Old Jan 6, 2003 | 04:47 PM
RaceTilIDie's Avatar
Default Re: eletrical oriented people..help making o2 simulator (BlueSi2k)
Most likely resistor values. Are you sure you have the right values? Do you know how to read resistor values? I would also test them with a good meter to make sure they are what they are supposed to be.
Old Jan 6, 2003 | 06:17 PM
BlueSi2k's Avatar
Default Re: eletrical oriented people..help making o2 simulator (RaceTilIDie)
I got the same values listed on the site. Even check every one of them. I guess my soldering could use some work but no 2 connections are touching that shouldn't be. Any other ideas?
Old Jan 6, 2003 | 06:22 PM
xXxS_SxXx's Avatar
did you try it with the car running?
and if you just holding it on the battery is it a solid connection
[Modified by xXxS_SxXx, 9:28 PM 1/6/2003]
Old Jan 6, 2003 | 07:19 PM
BlueSi2k's Avatar
Default Re: eletrical oriented people..help making o2 simulator (xXxS_SxXx)
I was using an old transformer that i measured outputing ~12.8v
After soldering a little better it now oscillates between 0v and ~1.2v and the 2nd led that comes one with the high voltage is very dim. Could this be because the transformer? Im going to try the car battery tommorrow but at least im getting some voltage now. Thanks guys
Old Jan 6, 2003 | 07:44 PM
xXxS_SxXx's Avatar
try the car battery its probally right car battery have a low voltage typically
Old Jan 20, 2003 | 05:06 PM
ultimatehonda's Avatar
What wire do you tap into in the ecu to hook up the sim?
Old Jan 20, 2003 | 06:26 PM
BlueSi2k's Avatar
Default Re: eletrical oriented people..help making o2 simulator (ultimatehonda)
i think my helms shows pin #23 on connector ?a? its a red/white wire
Old Jan 20, 2003 | 07:33 PM
When you hooked up urs did it work alright?
Old Jan 20, 2003 | 07:34 PM
carolinaACCORD's Avatar
it does sound like less-than-perfect soldering job.
also, most transformers wont put out enough amps, but then again thats not really a high current circuit anyway, so nevermind that.
Old Jan 20, 2003 | 08:32 PM
BlueSi2k's Avatar
Default Re: eletrical oriented people..help making o2 simulator (carolinaACCORD)
It worked perfectly hooked up to the car battery. The voltage flipped from 0v to .7v every 3.3 seconds. I havn't actually hooked it up to the car yet since i had to get my car inspected and put the cat back on. My car is still under warantee so im beginning to think twice about hacking my wiring. I may be willing to sell the sim if someone is interested. It cost me around $25 in parts so i would like to at least make that back. I might still decide to use it im just testing the waters here to see if i can sell it pm me with an offer.
Pure Sol
Nov 24, 2005 11:51 AM
imonkie
Jul 20, 2003 07:19 PM
REDBARON
Nov 2, 2002 01:22 PM
