Wacky oil drain fitting
So, I am in the process of attempting to set up my oil feed/drain lines. I have ALL of the archived posts. I am using AMstreetrod.com I have everything except one thing: the pipe to a.n. adapter for the oil drain. Subsequent trips to 2 pepboys and a homedepot lead me to believe the thread pitch is an 18. Does 9/16-18 sound like anything anyone has ever heard of? If that is the case I need an adapter as they don't have a 9/16-18 to -10 AN... But I don't care, I just want to know wtf the fitting size is. The turbo is a T-25 garrett off of a Pontiac Sunbird. Please help.
find a shop that carries earls or russel AN fittings they will more then likely have everything u need.
http://www.russellperformance.com/automotive/index.html
everyone uses earls but i found a russell dealer near me and they are the exact same fittings.
hit find dealer and see if theres one near you
hope that helps!
[Modified by shortyz, 5:35 PM 1/20/2003]
hope that helps!
South Bay Surfer
Jul 10, 2008 10:31 AM
ShawnR
May 11, 2007 01:07 AM
