5 wire to 4 wire O2?
I need to convert my 92 vx that has a 5 wire o2 into a 4 wire. I have a 4 wire with the plug and i was told that i can use 4 of the wires from the 5 wire to wire up the 4 wire. Does this make sense?? What wires do i use?? 5 wire has black, red, orange, yellow, and white wires. The 4 wire has 2 blacks, green and white. Is this going to work?? Thanks for the help.
i had this problem as well. just run the 4 wires from the o2 directly to the ecu. this is the eaiest way. if you need the pin locations i can get them for you. pm me.
Combustion Contraption
May 30, 2011 10:50 AM
slammedz6ef
Feb 15, 2008 07:46 AM
