Spoon camshafts
Old Jan 20, 2003 | 10:05 AM
margaflow's Avatar
New User
From: santo domingo, Distrito Nacional, dominican republic
Default spoon sports camshafts
Can someone give me the specs of the spoon sports camshafts for b16 engine.
And if someone have the dyno result.
Old Jan 20, 2003 | 11:38 AM
Kamin's Avatar
Default Re: spoon sports camshafts (margaflow)
overpriced underpowered
look into skunk2's, JUN or toda's
Old Jan 20, 2003 | 03:17 PM
Cal's Avatar
Cal
The are worked ITR cams.
For the savings in money and matching cam gears I would opt for the Skunk2 Stage One's which should pull better power than the Spoon cams anyways. Both will use ITR valvetrain. The Stage One is rumoured to make power to about 8700 give or take a few RPM.
Buy Skunk2. Save the extra $150 on cams and $125 on gears (compared to Spoon, shouldn't mix n' match to keep warranties in check) and get some Ti retainers, and a head gasket, or some dyno time.
If you don't tune them you will have no benefit from them outside of the additional noise they make.
I had all the cam specs but deleted them.
Personally for mild cams that use ITR valvetrain i would want a TODA A. These are pricey and have no real top end (7500+) but are a smooth midrange cam that has a few lumps to make agressive midrange and VTECX over.
Old Jan 20, 2003 | 08:01 PM
1GreyTeg's Avatar
I rarely do this but,
Did you SEARCH for this information first?
All if it is here in the TypeR forums archives; the dyno charts, the specs, the debates.
The Good, the Bad and the Ugly...
Geez that was a classic Clint flick.
A.
Old Jan 20, 2003 | 08:03 PM
B2FiNiTY's Avatar
I would pass on the spoon cams. Good road race cams but it won't give you much power up top over ITR/CTR cams.
Old Jan 20, 2003 | 08:05 PM
AJ PwR's Avatar
Intake 256@1mm lift Exhaust 245@1mm lift.
Spoon uses Honda cam cores to cut their cams and they are not worked ITR cams. Spoon cams doesn't require valvetrain upgrade for B16/18 engines and you can still rev your engine to 9k in a safe condition. Also, Spoon has tested their cams in Gr.A series and they are as durable as stock.
[Modified by AJ PwR, 9:06 PM 1/20/2003]
Old Jan 20, 2003 | 11:03 PM
Blade's Avatar
New User
Default Re: spoon sports camshafts (AJ PwR)
Group A race series was disbanded years ago and all Group A race motors were from Mugen, not Spoon. Spoon runs in N1 where camshaft modification is not allowed.
Old Jan 20, 2003 | 11:06 PM
Type-Rare#1248's Avatar
Default Re: spoon sports camshafts (Blade)
interesting
Old Aug 13, 2003 | 09:56 AM
AllMotr's Avatar
Default Re: spoon sports camshafts (Type-Rare#1248)
i have a set of spoon cams in my b16a and i love them, make power right to 9000 on itr head.
Old Aug 13, 2003 | 10:11 AM
BANting's Avatar
Default Re: spoon sports camshafts (AllMotr)
i think spoons are good, but id go with skunk2's i remember seeing a guy with a gsr dyno his car testing both camshafts.
Old Aug 13, 2003 | 11:07 AM
IntegraT's Avatar
Default Re: spoon sports camshafts (EG1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG1 &raquo;</TD></TR><TR><TD CLASS="quote">i think spoons are good, but id go with skunk2's i remember seeing a guy with a gsr dyno his car testing both camshafts.</TD></TR></TABLE>
Do you have a link to this test?
Old Aug 13, 2003 | 11:16 AM
IntegraT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> overpriced underpowered </TD></TR></TABLE>
It depends on how much you spend on them, and what your trying to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Personally for mild cams that use ITR valvetrain i would want a TODA A.</TD></TR></TABLE>
Why?
Modified by IntegraT at 8:32 PM 8/13/2003
Old Aug 13, 2003 | 11:29 AM
Mike M's Avatar
Founding Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blade &raquo;</TD></TR><TR><TD CLASS="quote">&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;Al so, Spoon has tested their cams in Gr.A series and they are as durable as stock.
[Modified by AJ PwR, 9:06 PM 1/20/2003]&lt;HR&gt;&lt;/BLOCKQUOTE&gt;
Group A race series was disbanded years ago and all Group A race motors were from Mugen, not Spoon. Spoon runs in N1 where camshaft modification is not allowed. </TD></TR></TABLE>
And Spoon Cams have been out for the B Series for years and Spoon Builds engines/Cars for other Race Team like CWestin & many others who race in series other than N1.
Old Aug 13, 2003 | 11:37 AM
Footwork's Avatar
I kinda like how the Spoon cams match up vs. the Toda A...
Spoon - 11.53 mm, duration - 256 @ 1mm 11.13 mm, duration - 245 @ 1mm
Toda Spec A - 11.6 mm, duration - 250 @ 1mm 11.2mm, duration - 240 @ 1mm
Paul
Old Aug 13, 2003 | 12:18 PM
GokuSSJ4's Avatar
Default Re: spoon sports camshafts (Primo.)
Spoon cams are great , they make good midrange and decent top end over the itr cams , but for the price that you pay for them .You are better of going with Toda A's , Skunk 2 stage 1 or Jun 1
if not something more agressive . an if you plan reving pass 8400rpms i would recommend valvetrain , is always better to be safe then sorry ....
Old Aug 13, 2003 | 12:50 PM
rodrez.'s Avatar
https://honda-tech.com/zerothread?id=145681
REAL TIME
Aug 19, 2014 05:06 PM
jansenrw
Mar 9, 2005 03:57 PM
dabomb
16
Sep 18, 2003 04:30 PM
p-boy
Apr 30, 2002 03:56 PM
ninjaman
Jul 9, 2001 08:01 PM
