main bearing colors?????
Old Jan 20, 2003 | 04:52 AM
SPEED123's Avatar
Default main bearing colors?????
rebuilding my block for stock ls motor.....i couldn't find the letters stamped on the block for the main bearing journals letters/color...but found the following on the crank......
b2, b2, b2, b2, b2........on the crank
3, 3, 2, 3....................on the rods
what color bearings do i need for the main bearings and the rods??
any help would be greatly appreciated...thanks
Old Jan 20, 2003 | 10:38 AM
sgT's Avatar
sgT
Default Re: main bearing colors????? (SPEED123)
on the crank you should have *4* letters and *5* numbers
on the block on the oil rail by the trans side you should find 5 letters.
you match the 5 letters with the 5 numbers to find main colors
and the 4 letters and the 4 numbers off the rods to find rod colors
92civtegra
Feb 29, 2008 04:24 PM
killingtwobirds
Sep 28, 2007 08:23 AM
GSR-C5
Jul 1, 2007 05:28 PM
panchovilla760
Mar 2, 2007 09:26 PM
NA JDM GSR
Nov 16, 2006 08:30 AM
