leakage around oil pan, and recall questions for 5th gens...
Old Jan 19, 2003 | 03:49 PM
SOHCMAN's Avatar
Default leakage around oil pan, and recall questions for 5th gens...
So I change out the crappy valvoline for some Honda Manual trany fluid today and decided to give the underbody a look over. Around the top of the oil pan there is a ring of liquid that appears to be dark brown oil when wiped off. no leakage from fill plug of the filter at all, its just where it bolts to the body. Im running Mobil1 synthetic 5w-30 and its only been in for about 1000 miles. Also just passed 120K on the engine if that helps at all, but what on earth could it be besides the obvious)leaking oil pan.
Second question. What recalls have been put on 94 LX sedans? Besides the oil seel clip thing? thanks!
sohc
Old Jan 19, 2003 | 04:59 PM
Chiovnidca's Avatar
Default Re: leakage around oil pan, and recall questions for 5th gens... (SOHCMAN)
There are no recalls on 94 Accords. BTW the balancer seal update campaign has expired.
Old Jan 19, 2003 | 06:11 PM
SOHCMAN's Avatar
Default Re: leakage around oil pan, and recall questions for 5th gens... (Chiovnidca)
well, hopefully the previous owner got it done!
sohc
Old Jan 19, 2003 | 07:23 PM
SOHCMAN's Avatar
up
Old Jan 20, 2003 | 03:04 PM
SOHCMAN's Avatar
up again... Why wouldit be leaking around the oil pan, its not squirting or anything, threis just a ring where it and the block meet.
Old Jan 20, 2003 | 03:37 PM
Hondaaccordvtec's Avatar
You may need to replace the oil pan gasket that seats between the block and oil pan. Kind of a PITA though because you need to remove the downpipe from the exhaust manifold just to get the oil pan.
Old Jan 20, 2003 | 08:10 PM
SOHCMAN's Avatar
Default Re: leakage around oil pan, and recall questions for 5th gens... (Hondaaccordvtec)
do these things just go bad? to my knowledge it has never been take off except maybe by Honda. Never been over heated, etc... THought it was one of those "things that should never need replaced"
sohc
Old Jan 20, 2003 | 08:13 PM
Accord94DX's Avatar
oil pan gasket seepage is very common in hondas.
Old Jan 20, 2003 | 08:14 PM
mikeyvt's Avatar
i just changed my oil a few weeks ago and i notcied that too, i have a 94 accord lx, think its just a gasket?
Old Jan 20, 2003 | 09:11 PM
Accord94DX's Avatar
Default Re: leakage around oil pan, and recall questions for 5th gens... (mikeyvt)
prolly
Old Jan 21, 2003 | 12:11 PM
twkdCD595's Avatar
Default Re: leakage around oil pan, and recall questions for 5th gens... (Accord94DX)
not uncommon, gaskets need replacing over time as they get brittle or what not.
Old Jan 21, 2003 | 12:44 PM
white95's Avatar
Default Re: leakage around oil pan, and recall questions for 5th gens... (twkdCD595)
So long as you dont start finding oil puddles under the car its completely normal.
Old Jan 21, 2003 | 12:55 PM
YeuEmMaiMai's Avatar
take the pan off get a neoprine gasket and some hi temp rtv gasket sealent.
do the following 10 easy steps after putting car on ramp stands and blocking rear tires
1. remove exhaust pipe from header
2. remove gasket
3. with a dremel tool remove all crap from the block and oil pan
4. apply a thin layer of high temp rtv sealant to the oil pan
5. place gasket on oil pan
6. let sit 10 mins
7. rebolt oil pan to block according to manufacturer specs
8. reattach exhaust.
9. add proper amount of oil
10 start car and check for leaks
remove car from ramp stand
Old Jan 22, 2003 | 07:17 AM
SOHCMAN's Avatar
Default Re: leakage around oil pan, and recall questions for 5th gens... (YeuEmMaiMai)
Excellent step by step YeuEmMiaMia, thankyou...
I think Ill wait until I get some drips though, it could just be the freezing cold shrinking the gasket or something...
cheers
sohc
AZ-Accord
11
Apr 11, 2013 05:16 PM
muscleman0745
Jun 3, 2010 05:05 AM
EM2_PLo
Honda Civic (2001 - 2005)
May 6, 2010 01:34 PM
hondaboy4life
Sep 29, 2006 08:01 AM
shming123
Apr 16, 2003 11:12 AM
