shifter bushings
Old Jan 19, 2003 | 11:25 AM
92CIVICCX's Avatar
Default shifter bushings
i replaced my shift linkage bushings yesterday but i can get the bolts of the end of the shift linkage that goes behind the shifter upwards in to the car.WTF? how can i take em out to put the wider polyurethane piece in i only go ti piece on the front of linkage in....
Old Jan 20, 2003 | 11:10 AM
fathergoose's Avatar
Default Re: shifter bushings (92CIVICCX)
remove your shifter console, then, ask someone to hold the bolts with vise grips inside the car. Go under the car snd remove the bolt, use a lot of loose nut. If you wanna make things easier, remove the shift rod from the transmission that comes with the shift lever, then, work on a bench, that's what I did
gursh d
14
Sep 18, 2007 09:48 AM
sickofitall1113
Apr 8, 2007 06:38 PM
slow_redcivic
16
Dec 29, 2005 04:06 PM
Nothing.Special
Jul 8, 2004 08:23 PM
wdskuk
Feb 13, 2004 03:54 PM
