wheel studs keep breaking on me since engine swap ?? need help
Old Jan 19, 2003 | 09:51 AM
lofer92's Avatar
Default wheel studs keep breaking on me since engine swap ?? need help
Since my engine swap from sohc to b16 my lugs come loose , usually when I find out one or two have already broke .. Ive replaced about ten over the last 4 months . The rims fit flush up against the hubs so it is not them .. I wonder since I have a bad strut in the front if this shakin it causes could make them loosen ...If not are there any aftermarket ones that are tougher or possibly longer.. thanks ..
Old Jan 19, 2003 | 01:45 PM
Chiovnidca's Avatar
Default Re: wheel studs keep breaking on me since engine swap ?? need help (SirHatchet2)
Are you using the proper style lug nuts? Are you torqueing them to the proper spec?
Old Jan 19, 2003 | 04:02 PM
HondaGSR's Avatar
Default Re: wheel studs keep breaking on me since engine swap ?? need help (Chiovnidca)
What lugs, and what wheels are you using??
JDMB20TDA
10
Apr 7, 2011 09:20 AM
egtony
Apr 6, 2010 05:02 PM
opera936
Sep 29, 2008 03:51 PM
snzh22
Jul 31, 2008 09:52 AM
Mike_C
Jun 10, 2004 09:25 PM
