Is .70 on exhaust side with a P-trim too big for a built for a ls.
Old Jan 18, 2003 | 09:23 PM
cock head's Avatar
Default Is .70 on exhaust side with a P-trim too big for a built for a ls.
Just curious or should I get a bigger one, it is ball bearing if that helps.
Old Jan 20, 2003 | 01:49 AM
pissedoffsol's Avatar
25 Year Member
Default Re: Is .70 on exhaust side with a P-trim too big for a built for a ls. (therumblingteg)
exhaust or compressor? are you sure you know what you are talking about?
Old Jan 20, 2003 | 02:01 AM
ninesecrx's Avatar
Default Re: Is .70 on exhaust side with a P-trim too big for a built for a ls. (delvtecsol)
I think thats fine...is it divided or undivided?
Old Jan 20, 2003 | 05:04 AM
ekb18c's Avatar
What's your compression?
Is this a street or track car?
Old Jan 20, 2003 | 05:33 AM
PM-Performance's Avatar
Default Re: Is .70 on exhaust side with a P-trim too big for a built for a ls. (ekb18c)
sounds kinda big to me ? if its the exuast side your talking about . . . mine is .63 and i ahve 10.6:1 compression and its still on the laggy side . high end flow is great though
Old Jan 20, 2003 | 10:41 PM
lugnuts's Avatar
Default Re: Is .70 on exhaust side with a P-trim too big for a built for a ls. (itr206)
.70 T4 is a divided housing
I use one with an O trim wheel, on a 2.0 liter motor with 9.0-1 c/r. It hits 28 psi at 5700-5800 RPM. I like it but I want more power (who doesnt)
Old Jan 20, 2003 | 10:48 PM
BudaKai's Avatar
Default Re: Is .70 on exhaust side with a P-trim too big for a built for a ls. (lugnuts)
That's one helluva Vee-Dub you have there.
If your still running racing "gas" try using methanol to get more power. You can at least turn up the boost some more then, and try to find some traction.
edit: You can go with a bigger TB with that compression too. Have you thought about getting some cams? I don't know if they are available, but a custom set designed for that much of a turbo could be very beneficial. Honda's also have a slight benefit with aerodynamics too. Some work on that brick like front end and venting your hood towards the back might also help. It's nice to see something besides Honda's out there being modded.
[Modified by tzsir, 1:55 AM 1/21/2003]
Old Jan 20, 2003 | 11:17 PM
ninesecrx's Avatar
Not all .70's are divided...
95civhb
Jan 4, 2010 01:49 PM
string
Sep 12, 2006 04:04 PM
z6
May 18, 2004 07:47 PM
Mr. Softee
May 12, 2003 06:53 PM
CM-R
Jan 24, 2003 02:27 PM
