question on max-rev manifold, 60-1 and c&r radiator??
Old Jan 18, 2003 | 08:54 PM
00ITR #543's Avatar
Default question on max-rev manifold, 60-1 and c&r radiator??
Does it fit? Will the fan clear the compressor housing?
thanks..
Old Jan 19, 2003 | 05:30 AM
00ITR #543's Avatar
Default Re: question on max-rev manifold, 60-1 and c&r radiator?? (00ITR #543)
up.. Has anyone done this?? With either a fluidyne, pwr or koyo, or c&r?????
Old Jan 19, 2003 | 06:27 AM
Farnsrocket's Avatar
Yes, but a little differently:
Old Jan 19, 2003 | 06:50 AM
VTEC-DA's Avatar
Default Re: question on max-rev manifold, 60-1 and c&r radiator?? (Farnsrocket)
Damn, talk about crowded.
Old Jan 19, 2003 | 09:12 AM
boosted hybrid's Avatar
I had a 60-1 with a maxrev manifold and dual wide pwr radiator in my eg hatch. I mounted two autozone aftermarket fans in front of the radiator, and I have no clearance problems what-so-ever. You can get away with a single core radiator with the fan mounted in front. Either way, just mount two pusher fans in front of the radiator and you wont have any clearance problems at all.
Old Jan 19, 2003 | 01:48 PM
00ITR #543's Avatar
That setup is pretty trick!!! nice!!
Old Jan 19, 2003 | 01:49 PM
00ITR #543's Avatar
Default Re: question on max-rev manifold, 60-1 and c&r radiator?? (boosted hybrid)
Was looking to see if anyone has it seup without the turbo reversed and the c&r of fluidyne radiator on an integra...
Old Jan 19, 2003 | 02:32 PM
Thanks! I can't answer your question, sorry!
Old Jan 19, 2003 | 03:00 PM
I didnt have the turbo reversed, it was mounted the standard way with the inlet facing the passenger side of the car. Either way you will need to mount the fans on the front as pusher fans, otherwise you will hit fans. I have maybe an 1" clearance between the turbo and the radiator as it is.
Old Jan 19, 2003 | 03:25 PM
00ITR #543's Avatar
What did you use for the bottom mounts of the radiator? I have a civic c&r and it won't fit if you line up the stock mount with the first foot of the c&r..
Old Jan 19, 2003 | 03:51 PM
I IM'd ya. Just drill out the stock welds on the mounts and position them for the new radiator and drill new holes and rivet them back on. My outer mount by the fender is actually on a piece of flat steel that is hanging from the frame. I don't have a pic of that, but here are some closer pics.
[Modified by Farnsrocket, 4:53 PM 1/19/2003]
Old Jan 19, 2003 | 04:26 PM
2K_TEG's Avatar
it will fit. It will def. fit if you get the civic sized core.
Old Jan 29, 2003 | 08:25 AM
baphomet's Avatar
Default Re: question on max-rev manifold, 60-1 and c&r radiator?? (2K_TEG)
any block shaving with the 60-1 and maxrev manifold?
Old Jan 29, 2003 | 08:29 AM
B18EG6's Avatar
DAMN again, awesome pictures. Is that a catch can? What kind?
to try to stay on topic, i loooove that radiator, how much was it and from where?
Old Jan 29, 2003 | 08:31 AM
Adi Radoncic's Avatar
On Fire!
Default Re: question on max-rev manifold, 60-1 and c&r radiator?? (b3435)
If you have the new style manifold that is made to fit a 60-1 along side a B-Series motor and you wanna have the compressor housing facing the passanger side of the car you will fit it with some minor shaving of the block webbing and the noch underneeth the engine code is also gona have to go....
Adi
Old Jan 29, 2003 | 08:54 AM
baphomet's Avatar
Default Re: question on max-rev manifold, 60-1 and c&r radiator?? (newgsr)
thanks for the reply
Old Jan 29, 2003 | 08:56 AM
Thanks! It's a Moroso Catch can....wanna buy it? I am gonna go without any catch can soon.
It's a PWR from ninesecrx, I wanna say $290 shipped.
Old Jan 29, 2003 | 09:22 AM
LsTurbo91's Avatar
Here's one. way better fitment, than the inline . t04s housing
More pics: https://honda-tech.com/zerothread?id=262087
Old Jan 29, 2003 | 10:05 AM
SiRkid's Avatar
Default Re: question on max-rev manifold, 60-1 and c&r radiator?? (LsTurbo91)
yup
Old Jan 29, 2003 | 10:12 AM
paulzy's Avatar
Damn Jon...were you hovering over the car in the air when you took that shot?
Old Jan 29, 2003 | 10:54 AM
Default Re: question on max-rev manifold, 60-1 and c&r radiator?? (1320development)
Ha, ha! I actually crawled up into the rafters of my garage and took it from there!
Old Jan 29, 2003 | 11:23 AM
MikeMAN's Avatar
lol, sure you just didn't jump real quick and snap a pic?..hehe
mike
Old Jan 29, 2003 | 09:55 PM
B18EG6's Avatar
why u going without a catch can?
Old Jan 30, 2003 | 05:13 AM
Default Re: question on max-rev manifold, 60-1 and c&r radiator?? (B18EG6)
Well, after reading up on the subject, I wanna have an open system and not worry about my PCV valve closing on boost. Just seems a little better for the engine.
lsvtecEM1
Mar 19, 2012 05:18 AM
Tootsie7944
Feb 9, 2012 01:56 PM
aasaa666
Oct 22, 2007 08:15 PM
4piston
Jan 27, 2005 07:11 PM
