Cleaning Combustion Chamber, how?
Old Jan 18, 2003 | 05:56 PM
Colin's Avatar
Default Cleaning Combustion Chamber, how?
I just pulled my head off this afternoon to change the head gasket. The motor has been running rich so there are a lot of deposits on the pistons and around and on the valves. I'd like to clean this up as best as possible before i put the head back on. Any tips? Oh, and i don't have the $$ to take it into a machine shop and have them hot tank it and what not....its gotta be something i can do myself.
thanks
colin
Old Jan 18, 2003 | 10:00 PM
t0p_sh0tta's Avatar
Default Re: Cleaning Combustion Chamber, how? (91IntegGS)
Solvent maybe? Around here they only want $20-30 to hot tank a block.
Old Jan 18, 2003 | 10:43 PM
Colin's Avatar
Default Re: Cleaning Combustion Chamber, how? (t0p_sh0tta)
"solvent" care to be a little more specific? there are TONS of different types of "solvents.
Even if i wanted to take it into a shop, or could afford it, I couldn't because its the weekend and they will all be closed. I need to put the head back on tomorrow or monday in order to be able to drive to school on tuesday. But thanks anyway.
Anyone else?
Old Jan 18, 2003 | 10:56 PM
SpoonFedHatch's Avatar
just use carbureator cleaner or throttle body cleaner.....spray, remove, and wipe away
Old Jan 19, 2003 | 12:46 AM
Quik Chris's Avatar
Default Re: Cleaning Combustion Chamber, how? (SpoonFedHatch)
Step 1: Go snag little bro's toothbrush
Step 2: Get some carb cleaner, spray and brush.
Step 3: Wipe w/ paper towel, then spray w/ WD-40
Old Jan 19, 2003 | 11:43 AM
Colin's Avatar
The black deposits are coming off pretty well now, but there are some really hard deposits stuck on the valves...not sure what it is, but that stuff just doesn't wanna come off.
Old Jan 19, 2003 | 12:07 PM
yeeah just go at it with a metal bristle brush and some carb cleaner....it should evenutally come off, just be careful that you dont brush hard on the valve seals or anything
KidRuthless
Dec 3, 2013 08:58 PM
PatrickGSR94
Jul 16, 2013 10:01 AM
WishinItWas
Aug 22, 2007 02:58 PM
Unjockable
Jan 25, 2005 10:50 AM
rasta420
May 21, 2003 08:15 PM
