Short Shift Adapter kill synchro's???
Old Jan 18, 2003 | 10:32 AM
slow02ss camaro's Avatar
Default Short Shift Adapter kill synchro's???
I have a dumbass friend that works with me and I told him I just put on a DC short shift adapter and he said they kill your synchro's? Just to be safe, any truth to this???
Old Jan 18, 2003 | 11:26 AM
drift's Avatar
New User
Default Re: Short Shift Adapter kill synchro's??? (slow94accord)
nope.
Old Jan 18, 2003 | 11:42 AM
PupaScoopa's Avatar
Default Re: Short Shift Adapter kill synchro's??? (drift)
There is some truth to this. If you shift fast, the overall movement in the transmission is also changing ratios faster. When you do this, the synchros are forced to work harder to get the input shaft up to speed faster. Over time, this WILL cause failure.
Solution: Use the short throw as simply a convenience feature. Don't rely on it to shorten the time between ratios in a shift.
Old Jan 18, 2003 | 11:54 AM
Boostless97Lude
Guest
Posts: n/a
to be honest, i had more problems with the car not going in gear and what not BEFORE i installed a short shifter
Old Jan 18, 2003 | 04:07 PM
PrecisionH23a's Avatar
Default Re: Short Shift Adapter kill synchro's??? (Boosted97Lude)
prelude synchro's are notorious for going bad, especially 3rd gear.
Old Jan 18, 2003 | 11:38 PM
rjr162's Avatar
Default Re: Short Shift Adapter kill synchro's??? (GudeH23a)
I thought it was 5th ?
Old Jan 19, 2003 | 04:56 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Short Shift Adapter kill synchro's??? (rjr162)
yeah, 5th gear is the worst on the 5th gen. although ALL honda manual trannys are notorius for 3rd gear syncro going bad
Old Jan 19, 2003 | 05:59 AM
optikal_blitz's Avatar
Default Re: Short Shift Adapter kill synchro's??? (PupaScoopa)
does this same theory apply to short throw shifters? (not an adapter) i.e.4bidden motorsports shifter
Old Jan 19, 2003 | 06:37 AM
rjr162's Avatar
Default Re: Short Shift Adapter kill synchro's??? (NatakuBlitz)
any short shifter will allow you to throw it in gear quicker, whichs means you're hitting the syncro's that much sooner
Old Jan 19, 2003 | 06:54 AM
papa_smurf's Avatar
5th gear on 4th and 5th gen manual transmissions acts up not because the syncros go bad but because honda designed a weak arm inside the transmission that works 5th gear, it bends it you abuse it too much, i had it happen to my car before i got it and i had the pleasure of replacing the transmission b/c of it.
Old Jan 19, 2003 | 07:21 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Short Shift Adapter kill synchro's??? (papa_smurf)
so you guys are sayin if i get abusive while shifting i'll be in need of a new clutch? damn luckily my lude ain't a daily driver.
Old Jan 19, 2003 | 07:32 AM
LJR-LUDE01's Avatar
I had mine syncro work on about 4th month ago... it had been going bad a few times before but I manage to get it working just by keep driving it it would settle in place pack again but the last time it wasn't going no where so i had to take it to the dealership and they try to say that since I had modify my car (teins)they might not cover it... bastards... I still had it fix since that suspension dind't have to do jack with the syncro gone bad.... at the end they told me it was some kind of solenoid not sure since I didn't pick up my car but my wife did.....
Old Jan 19, 2003 | 09:19 AM
smokin rubber's Avatar
Default Re: Short Shift Adapter kill synchro's??? (StickyTires)
no, they are saying that if you shift too fast with or without a short throw, you will wear your syncros.
Old Jan 20, 2003 | 06:20 PM
* B A N N E D *
Default Re: Short Shift Adapter kill synchro's??? (smokin rubber)
thanks
jumpin4abeat
Jun 30, 2011 06:55 AM
EG6 Love
Transmission & Drivetrain
13
Dec 12, 2010 07:13 AM
EG6 Love
Dec 10, 2010 07:04 AM
dem0nk1d
13
Oct 8, 2007 08:49 AM
hobo79
Aug 8, 2001 09:11 AM
