noob question: how do you know when...,
Old Jan 18, 2003 | 12:09 AM
sloppy_seconds's Avatar
Banned
Default noob question: how do you know when...,
your water pump is going? my car was over heating the other night AND i had no heat through the vents. is this a bad water pump?
thanks in advance, and YES i searched
Old Jan 18, 2003 | 12:17 AM
WRXSTIle's Avatar
Default Re: noob question: how do you know when..., (slowasscx)
it leaks.
Old Jan 18, 2003 | 02:00 AM
EK MONEY's Avatar
could be, check the thermostat and make sure thats working. check the coolant level, see if the fan is coming on when its supposed too. Make sure you do the needed maintanance when the factory says so. If not, that could leed to problems..
good luck!
[Modified by Peagreenhatch, 11:00 AM 1/18/2003]
Old Jan 18, 2003 | 06:38 AM
Banned
Default Re: noob question: how do you know when..., (Peagreenhatch)
thank you guys!
bitek
15
Mar 4, 2009 01:07 AM
WhiteOnRice
11
Nov 30, 2007 12:59 PM
dc2415
Jul 1, 2007 08:51 AM
christiian
18
Jul 16, 2006 12:03 AM
Eyewitness
Aug 18, 2003 08:11 PM
