need help with brake master cylinder....
Old Jan 17, 2003 | 11:52 PM
im_poor's Avatar
Default need help with brake master cylinder....
Has anyone put in a 1" Integra Ls brake master cylinder into a 96 hatch???? and is it possible??
Please help me out.
Old Jan 17, 2003 | 11:54 PM
IM ALL BOB's Avatar
Default Re: need help with brake master cylinder.... (impoor)
are u using the stock civic booster? and the LS never came with a 1" MC usually a 15/16 unit..though I heard Honda did mis match products at times in the brakes department.. I don't think you can use the stock civic booster with the new MC
good luck
Old Jan 18, 2003 | 12:03 AM
im_poor's Avatar
Default Re: need help with brake master cylinder.... (IM ALL BOB)
good luck
im using the ls master cylinder and booster the cylinder has a 1 on it so i assumed it was a 1" ...but when i mounted it, one of two brake lines would fit, the other hole was too big.
Old Jan 18, 2003 | 02:02 AM
EK MONEY's Avatar
I used a 2001 integra FOUR DOOR and that worked with no bending at all. I know for a fact that that is a 1 inch. That is on a 96 civic. Good luck!
Old Jan 18, 2003 | 05:05 AM
9KRacer's Avatar
New User
Default Re: need help with brake master cylinder.... (Peagreenhatch)
I'v got one from an R, looks like it lines up. I just havent put it yet..
Old Jan 18, 2003 | 12:24 PM
ejprimo's Avatar
Default Re: need help with brake master cylinder.... (9KRacer)
this should help:
https://honda-tech.com/zerothread?id=152884
wwhitby
Honda Civic (2001 - 2005)
Feb 27, 2017 02:28 AM
DC5_lov3r
Apr 16, 2008 07:28 PM
integra123
Aug 8, 2006 05:52 PM
