CenterFOrce Clutch >?
DOes anyone know about the centerforce if it is good not . I just ordered one Hope I didnt waste my money.. If you do please reply . I got the CF dual friction Clutch ... ???????
"any aftermarket clutch is good"
you sure?
you sure?
i got a centerforce in my car
Its ok but when i would be on the street and shift to secend going like 15mph and doing a rolling burn out and then while am still shiping ill try to go to 3rd it would slip some time but only if i been driving the car all day
Not very big in clutches . What is so good about a racing clutch. it makes you peel out longer , chreap gears etc.???? also why did it slip goin in to 3rd gear when doing a rolling burn out. Can wait til I get my CF dual friction clutch in.
it just shows that it cant hold but so much power i think was making around 300whp back then but i hope this year its holds up i should be making around 400whp
Cant wait til I get my clutch in ? Just gotta wait til I break in the clutch so i can go 2 the track. Since racing clutches grab alot bettah . WOuld it take anything off my 1/4 mile time ??
Nah, I don't think it would really make a big difference, unless your stock clutch was slipping. The real difference would be if you swapped to cable clutch.
I didn't give any numbers on the Centerforce clutch. It all depends on the way you use it, and the guy I was referring to had an AWD Talon with 300wtq, so the clutch probably had to endure more than it was designed for.
