4th Gen VTEC Turbo?
Old Jan 17, 2003 | 06:07 PM
96LudeSiVTEC's Avatar
Default 4th Gen VTEC Turbo?
I have a 96 Prelude VTEC with 60000 miles. I have been trying to decide between NA or FI. But my biggest dilemna is FI. Is the H22A1 a good format for turbo? Or am I looking at putting a ton of money into the motor just to get ready for turbo?
And yes I did a search and ended up with no answer.
Old Jan 17, 2003 | 06:37 PM
H22Prelude's Avatar
Default Re: 4th Gen VTEC Turbo? (96LudeSiVTEC)
You're probably going to get a lot of opinions on this one, but here's mine anyway... I've got the same exact year and engine w/ 100k miles on it. I've got the FMAX kit (Turbonetics T3/T4) and it's done me good. Yes, I paid a pretty penny for it but like people say you get what you pay for. I've dynoed it once and got some pretty impressive numbers (273hp w/ 232 ft lbs of torque @11psi). That was with the two additional Lucas 440cc injectors on. I've rebuilt my turbo and motor since then. Now I'm currently running between 8 and 9 psi on STOCK internals. The only thing I did to the motor was: Put oversized stock pistons in, and a cometic headgasket (i believe it's .53mm). I runs good with stock internals...Less lag. Now, i do think that if you want to run more than 9 psi daily then I would say resleeve and get some forged pistons. Good luck!
Oh, and if you're wondering if VTEC will give you a little extra kick with a turbo...it won't. You'll never feel when VTEC kicks in with FI.
[Modified by H22Prelude, 10:40 PM 1/17/2003]
[Modified by H22Prelude, 10:41 PM 1/17/2003]
Old Jan 17, 2003 | 07:24 PM
BoostedH23a1's Avatar
Default Re: 4th Gen VTEC Turbo? (H22Prelude)
h22 is a good turbo motor.. only thing is it doesnt like over 8-9 psi boost stock.. thats due to the ringlands on the pistons... other than that go for it.. i did..
250whp 222tq at 7psi...H23 that is
Old Jan 17, 2003 | 08:48 PM
LudeyKrus's Avatar
Default Re: 4th Gen VTEC Turbo? (BoostedH23a1)
I've heard the ringlands are prone to failure in H22's when boosted, but is it the same for H23's? I've never actually heard of an H23 breaking a land
Old Jan 17, 2003 | 08:53 PM
Cottonwoodz's Avatar
Default Re: 4th Gen VTEC Turbo? (LudeyKrus)
They are weak in every honda motor
Old Jan 17, 2003 | 09:54 PM
H22Prelude's Avatar
Default Re: 4th Gen VTEC Turbo? (Cottonwoodz)
Very true about the ringlands. My pistons were cracked as well as the ringlands before the motor was rebuilt. But then again that was @ 20+ lbs. of boost. (sucks when the vacuum hose to your wastegate melts and you have no other way to control boost.)
Old Jan 18, 2003 | 04:45 AM
Boostless97Lude
Guest
Posts: n/a
not true...... B-series guys can push 15+psi on STOCK bottom ends all the time without ringland problems
gregory
12
Jan 9, 2007 09:16 AM
icebergli
Jul 18, 2005 07:44 PM
StreetRacinThug
Oct 12, 2004 02:25 PM
Luserkid
Jan 25, 2003 08:50 AM
Immortal23
Oct 10, 2001 07:56 PM
