oil pan gasket pinched?
Old Jan 17, 2003 | 05:04 PM
escocrx's Avatar
Default oil pan gasket pinched?
I am rebuilding my motor. and now to the oil pan gasket. The easiest part yet. But why IN THE HECK does the gasket pinch and get all deformed? Is this bad? Is it supposed to pertrude out all around the bolt areas? Some are more extreme than others? Did it not seat properly? I used hondabond all around it.
Any tips? Or just reason for this pertruding gasket. I'm doing 12Nm all around. Is this bad? Or normal? I am going to clean the area and retry it. But geeeez easiest thing turned into a big headache.
Old Jan 17, 2003 | 05:40 PM
texan's Avatar
Default Re: oil pan gasket pinched? (escocrx)
the only tip I can give is that next time, purchase the ARP pan studs. They'll have the pan perfectly aligned with the block by the time the gasket seats.
Old Jan 17, 2003 | 05:59 PM
tominos's Avatar
u can just use gasket sealant all the way around the pan before you put it on. works just as good. i thought the gasket looked like a rubber line that sits flush almost with the pan.
Old Jan 17, 2003 | 06:10 PM
escocrx's Avatar
OK. all i did was use hondabond all the way around. And hand tightened till it started slightly pertruding out. and stopped. Its not to torque specs though. Which i kinda wanted. Hopefully bolts wont jus rattle off.
Old Jan 17, 2003 | 07:40 PM
b19coupe's Avatar
Honda puts the oil pan gasket on dry, no Hondabond. It works better that way. Gasket squishes out if you use Hondabond, as you have discovered.
Old Jan 17, 2003 | 07:58 PM
escocrx's Avatar
Default Re: oil pan gasket pinched? (b19coupe)
hhahaha thanx.
as usual. operator error.
thanks
Old Jan 17, 2003 | 08:49 PM
tnbigdawg's Avatar
I use hondabond on my gaskets, and it doesnt do that.
make sure you use a new gasket cause an old one would do that.
george34
Nov 9, 2016 09:44 PM
imadigitalgod
Apr 8, 2010 09:48 AM
StreetRacinThug
Dec 21, 2006 08:44 AM
DualCamDan
Jul 26, 2005 04:19 AM
keebler65
Oct 4, 2002 08:40 AM
